Problems with my 52"
My television keeps turning itself on and off sporadically do you know what could be the situation? I would rather not pay a repair man $400 to fix my tv.
    Novelist:
    Champion:
  • 275 Answers
Loose Connections or Cold solder in the Mains Supply board.
Posted on Apr 09, 2008
As stated above very often it is a cold solder connection. Look for solder to be shiny and re-heat with fresh solder any connection that looks gray in color. If you have a meter you can try to check continuity between the joint and the next component. Try to shake the component and see if you lose connection (resistance goes from ~ 1ohm to higher level and back, then resolder that connection by removing old solder by reflowing and sucking it with a solder removal tool or solder "wick". Then reheat with fresh solder. Iron and all tools needed available at HW store.
Posted on Oct 10, 2009
SOURCE:
My 2004 rca hdtv keeps turning itself off when i turn it on
I do wish i had more but one thing that will cause a problem like this is spraying air freshener or spray cleaners where the spray can get inside the back of the TV. It will also cause it to pop. Hope its this easy to fix for you, good luck.
spray the cleaning rag then wipe TV clean.
Jun 25, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
Screen goes black sporadically. Have to turn off TV and turn back on. Gets worse the longer it's on
This tv problems is the power supply board problem,it degrading and it dying.That the board,where the power a/c cord plug into it.The tv is getting weaker and weaker powering up voltages in.Tries websites like Shopjimmy.com,Ebay.com to buy a whloe refurbish power supply board for the replacenent.
Dec 19, 2010 | Samsung LNT5265F 52 in. LCD HDTV
AE-740 Typewriter: Nakajima AE 740 keeps typing "tc" sporadically and...
It sounds like a keyboard problem, maybe a spill, if so lit it sit on its side for a couple of days it may dry and heal itself, otherwise you will need a tech.
DickyO
May 17, 2010 | Nakajima AE-740 Typewriter
It keeps shuting off by itself
I found the answer by taking it to a tv repair. the problem was the ballist the controls the lamp. 105.00 total parts and labor. so all my friends with LG rear projection TV'S check ballist if set keeps turning on and off by itself.
Dec 17, 2009 | LG RU-52SZ51D 52" Rear Projection...
Have a 52 inch Mitsubishi TV. Just replaced the
Call Mitsubishi the chassis needs to be rebuilt on this set they have been paying for the parts but you will have to pay the labor.
Oct 13, 2009 | Mitsubishi WD-52725 52". Rear Projection...
52-52 HM84 there is sound no picture there is flashing green light and steady red light. Television shuts down after a few minutes. Thanks Felipe [email protected]
Seems like you might have a bad CAP " capcitor in your powers supply unit. How you can tell this? Opening up the unit and do a HI POT test on your power supply unit and check for faults. You have to be qualified to check this and know what your doing otherwise you could recieve a nice jolt and pay a few hundred for a EMS to revive your heart. So leave this one to the experts if you do not know the logistics of this issue. Assuming your asking me a repair tech would consitute you do not know whats going on seek qualified help.
1. replace powersupply unit
or
2. Rebuild power supply by replacing the caps inside that have tested bad.
Good luck to you on whatever your situation may be but as always Thanks for asking me first!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Sep 23, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
Volume does not work
check for loose solder and the system ic
Jul 17, 2009 | JVC HD-52G787 52" Projection Television
Tv turns itself off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 31, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
52" RCA Rear Projection.
This will require tech repair.. the processor is dectecting problem. does the green light flash?
Nov 17, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
Top Televison & Video Experts
Ekse
