Question about Simplex Kaba Ilco Unican 1011 keyless lock without key override
How do I change the combination on a kaba 1011
  • 963 Answers
SOURCE: need to find instructions to
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Good Luck!
Posted on Mar 06, 2011
  • 963 Answers
SOURCE: How do I change the
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Customer service can be contacted from this link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Good Luck!
  • 963 Answers
SOURCE: i need a kaba ilco
wentlanv
  • 710 Answers
SOURCE: Need to change the combination
Hi Don,
Got these instructions from: >>>> http://www.indra.com/archives/alt-locksmithing/hobbit.html >>>>
"Once you know the current combination, you might want to change it. Instructions for doing this undoubtedly come with the lock; but it's real easy. There is a screw in the top with a hex hole; remove this from the lock body. Dial the proper combination, but don't move the handle. Press straight down through the hole with a small screwdriver, until you feel something go "thunk" downward. The lock is now in change mode. Reset the tumblers [leftward twist], enter your new combination, twist the handle as though opening the lock, and your change is now in effect. Re-insert the screw. This does the following: The thing you hit with the screwdriver pushes the tumblers down onto the locking bar [which is why the proper combination must be entered], and disengages them from their idler gears. Button presses turn the *idler* *gears* around, and then the opening action shoves the tumblers back up to mesh with these gears in their new positions. A subsequent reset mixes the tumblers up again to follow the new combination. This description is admittedly somewhat inadequate; the right thing to do is take one of the locks apart and see for one's self what exactly happens inside."
Hope this helps. If it does. I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 16, 2011
  • 963 Answers
SOURCE: how do i change the
I'm not sure of your exact model, but I think you will find the information that you need listed on this grid chart:
You can cut & paste the link or type it into you browser's search bar.
Hover your mouse over the right-most column (Tips) for your model and you will pop up links for Changing the Code or Resetting the Code.
These are PDF files, requiring that you have Adobe Reader or equivalent installed on your computer in order to view them. If you're not able to view them install Adobe Reader from this link:
http://get.adobe.com/reader/
Posted on Jul 14, 2011
Kaba lock won't open with code
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Aug 18, 2012 | Simplex Kaba Ilco Unican 1011 keyless...
Unican keypad door lock reset?
You will find a link to download the manual for your model on this page:
Hover your mouse over "PDF" under the "TIPS" column and the two choices of "Changing the Code/Combination" or "How to Reset a Lost or Unknown Combination" will appear--move your mouse over the appropriate one and click to download the info.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader, if the file will not display for you.
Good luck--and please provide feedback if this helps!
Oct 24, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Model 1011... door opens without any combination. how do i fix the lock to open only with combination?
"If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution
Solution: Follow the procedure for changing a combination except omit step 3 (do not enter
the existing combination)."
I excerpted the above from the full instructions on how to change the code. If you don't have them, got to this link:
and go across from L1000 to the last column, "Tips".
When you hover your mouse over PDF, two choices will appear; left click on the upper one, "Changing the code/..." to download it.
The download will be a PDF file format. If you are unable to open it, you will need to download and install Adobe Reader on your computer. There is a link (Get Adobe Reader) at the top right of the literature grid.
When you do get the download open, you will have the stepwise procedure and illustrations necessary-but don't forget to omit Step 3, if you believe that you have the ZERO code problem!
Aug 15, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Door opens without any combination. how do i fix the lock to open only with combination?
How do i change the combination on a simplex 1011 door lock
Jul 11, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
Is there a way to prevent theft of the Kaba Ilco 1011 besided Locktite? Thanks, Walt
I can't help you directly, but I will steer you to further information.
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
You can contact their customer service for more technical information.
Jan 11, 2011 | Simplex Kaba Ilco Unican 1011 keyless...
How do I change the code on the Kaba IIco Unican 1011 keyless lock?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
aspx?id=13
Good Luck!
Dec 21, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
I have forgotten the code for my code lock which is on my bedroom door.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Reset combation without a combation kaba
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Sep 29, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Simplex Kaba Ilco Unican  1011 keyless lock without key override Logo
237 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
JonSnell Electronic
JonSnell Electronic
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
