Question about Lowrance GPS
Lowrance LCX-16ci - screen's gone out
I have a Lowrance LCX-16CI (only 5 years old) and the screen is "out". I believe the unit is working as I can hear the transducer "clicking" and the GPS aquiring position (I still have sound). Lowrance says they don't work on these any more and that I have to replace the unit. Do you have any suggestions or know of anyone who works on them. The problem with replacing it (besides the obvious cost!!) is that the transducer and the GPS antenna have to be changed out as well.....not a fun job.
  • Anonymous Mar 26, 2014
    I need transducer
I have a working unit with a bad antenna. Interested?
Davidwcantrell@comcast.net
Posted on Aug 07, 2008
Did you ever get it going let me know todd123@live.ca
Posted on Jul 28, 2008
Do you still have the unit? Thanks
Posted on Dec 18, 2009
Need Lcx 15 mt update 3.6.0
You might find what your looking for here.
http://www.lowrance.in/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-360/
Jun 13, 2014 | Lowrance Boating
Lowrance LCX 28c HD with Navionics HotMaps Premium SD chip. Chip worked fine last fall but when I went to use yesterday the Lowrance would not read the chip.
I had the same problem with my handheld Lowrance Hunt C. After installing the card and locking it in place, I had to slide the card "out" toward the locking mechanism. It barely moves, but worked after that. Whenever I load the card, I now slide it out or wiggle it and it works every time.
Apr 20, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
Hi i have had the lcx- 15 since 2001. i would like to update the software. plus the latest manual.
Here's the link to then manual => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Here's the link to software updates page => http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Here's the link to the most current software available from Lowrance =>
http://www.lowrance.com/en/Products/Marine/Large-Screen-SonarGPS-Chartplotter-Combos/LCX-15-MT/Downloads/LCX-15-MT-Software-Update-310/
Please leave feedback. Thanks in advance.
Dec 07, 2008 | Lowrance LCX-15MT GPS Receiver
Lowrance LcX 27C
You need to get a MMC card for it to show Canada.
Jul 02, 2008 | Lowrance LCX-27C GPS Receiver
Lowrance LCX-19C GPS Receiver Problem
It sounds like you may have to send it out for service, but before you you do there are a few things you can try.
Low voltage can cause erratic behavior. Since you already wired directly to the battery, check the plug for corrosion.
Try unplugging the transducer cable to see if the display still behaves erratically. You wont see depth readings but you should still see the screen going black. If no erratic behavior with transducer unplugged then problem is in the transducer cable or the plug. A common source of failure is at the plug because the added stress of plugging and unplugging cables can cause the socket to twist slightly which can cause a short.
Make sure you have the latest software update.
How to see if your LCX-19C is already using version 1.8.0 software:
  1. Press the MENU button twice on your LCX-19C.
  2. Select SYSTEM SETUP.
  3. Select SOFTWARE INFORMATION.
  4. The software version for your unit is located under the line that says "LCX-19C" (ex. "Version 1.8.0").
  5. If your version is the same version listed above, there is no need to download the software.
If it is lower than 1.8.0 you can download the update from this link: LCX-19C UPDATE
Copy it onto a blank MMC card and install it in your GPS. The GPS should prompt you on how to install the update.
If you need to send the unit in for service click this link: LOWRANCE SERVICE
Mar 15, 2008 | Lowrance LCX-19C GPS Receiver
LCX-19C - Screen displays backwards
I have the same problem on my unit and was told the same after I stayed on hold 38 minutes for tech support at lowrance. This is the second Lowrance that they would not fix and only offer a "discount" on a replacement. This company can KISS my behind. What a scam!!!
Aug 04, 2007 | Lowrance LCX-19C GPS Receiver
GPS Logo
825 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
