Question about RELIANCE ELECTRIC WATER HEATER
I have to press the reset button every day, what is wrong, thank you!!!
  • 349 Answers
Thermostat is tripping out due to thermostat or element may be going bad. Also take a look at the element's wire's connected to them and make sure there are no burn places. Because the thermostat will trip out for safety of the heater.
The thermostat's and elements are not exspensive to replace. Please inspect them very closely and be safe.
If you replace the thermostat please turn power off and changing the elements turn water off.
If elements need changing fill heater and get all air out of lines before turning the heater's power on.
Posted on Jun 02, 2010
Brand new electric hot water heater doesn't get water hot
Call Rheem
Reset breaker fully off and then fully on.
Test for 240 Volt across top two screws on upper thermostat
Press reset button located on upper thermostat
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#reset
Gene
Water Heater Timers Save Money
Jul 01, 2014 | Rheem Water Heaters
Please help!! I can't find the reset button on my Rheem 81V52D C model water tank! I opened the top panel and didn't see a red reset button. Totally confused now. Please help?
if there is no reset button, you should be able to turn the breaker off for a few minutes. then turn it back on. if its an electric water heater! it should reset it. good-day !
Mar 26, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Continuous ignition failure code comes up every day have to shut off powervent switch and on and unit will instantly turn on. problem began intermittently now happens every day. tired of resetting switch...
Hello
You need to unlock disply by holding down the up and down buttons until the lock flashes then goes away.
Once inlocked you can press mode button to resume normal operation.
Here is a link for your HW heater.Note pgs 22 to 24.
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
Aug 26, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
HELLO, MY WATERHEATER KEEPS TRIPPING THE RESET BUTTON ABOUT TWO TIMES A MONTH. WHAT COULD BE THE PROBLEM?
could be faulty thermostat/reset button, or shorted element. Breaker to water heater off,
Check elements for continuity to ground. should be no continuity to ground. If elements OK replace reset button. If you have noticed very hot water and elements checked OK then replace both thermostats along with reset button
Feb 17, 2010 | Reliance & 50gal Electric Water Heater
Top thermostat reset button kicks out
The top button is connected to the top heater element  which is likely shorting out. Drain the tank below the element that the thermostat is attached to. Remove and replace the element
Jan 24, 2009 | RELIANCE ELECTRIC WATER HEATER
Residential electric hot water heater throwing br
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Dec 28, 2008 | RELIANCE ELECTRIC WATER HEATER
RELIANCE ELECTRIC WATER HEATER Logo
627 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
