FixYa.com
Tags:
VCRs
Generic problem for all VCRs
Akai VSG285 video - I can't tune any TV stations...
posted by deb1212 on Apr 09, 2008
Can anyone help? I have a Akai VSG285 (no manaul) & I can't pick up any TV stations thru the VCR. I can watch video's on the dam thing, but I can't tune any TV stations onto the VCR so I can tape the programs. HELP!!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 09, 2008
Not Rated (0)
dodgecharger
Rank:Wiz Wiz
Rating: 82%, 253 votes
This sounds like a hookup or programming problem.
The typical hookup is cable/satellite box output to VCR antenna/RF input, then VCR antenna/RF output to television input. Since you are able to watch pre-recorded tapes, the latter is already correct. There are other ways to connect, using the audio/video outputs of VCR to audio/video inputs of the TV. Older or low end TV sets may not have these connections.
If by chance you are using an outdoor antenna (not cable or satellite) then the antenna connects to VCR antenna/RF input and VCR output as above. You will also need to program the VCR into the stations- most late VCRs will scan for active channels, and program themselves to those channels.
I'm not sure of the capabilities of newer cable & sat boxes, but generally, you had to tune that box to the channel you wanted to record. The VCR is set to channel 3 or 4 depending on the output of the cable box.
Lastly, most VCRs of the last 10+ years require the remote to setup advanced functions, such as timed record, date & channel setup functions. The buttons on the VCR itself only do very basic functions, Stop/Play/Rewind/F-forward/Eject etc.
If you don't have the orig. remote, some universal remotes may be able to do advanced programming functions.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Audiovox AVP7000 VCR GE VG4250 VHS VCR GE VG4270 VCR Panasonic PV-V4540 VHS VCR GE VG2050 VHS VCR Panasonic AG-DV2500 DV/Mini DV VCR Panasonic AG-MD830E S-VHS VCR
Can you Help with these VCRs problems?
Panasonic PV-920 Dual Deck VCR
power surge
we have a vcr/dvd panasonic and... Answer This...
VCRs
timer recording, more than 1...
I have a Sylvania 6260VF VCR. I... Answer This...
Sony UVW-1800P VCR
Sony UVW-1800 BetaSP deck
I have a 10 year lod deck that... Answer This...
Panasonic AG-DV2000 Mini DV VCR
DV Deck not loading tapes...wtf
im having some trouble with my... Answer This...
Sony SLV-N750 VHS/S-VHS playback VCR
Stuck tape
I entered a tape, recorded onto... Answer This...
Repair Service
Find VCR Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
