Question about SanDisk Sansa e260 MP3 Player
Windows Media Player won;t sync music!
Hey, Hopefully you could help!
My sansa started with a problem, that would say bad track so I decided to format the device in Windows Media Player but then It didn't format completely, there are couple of folders which I delete but never get deleted, I tried to format as someone her in fixya suggested but no it didnt work, they just stay and now I can't syncronize my sansa in window media player.... I dont know if this helps but i tested my mother's sansa and it did syncronize all the music I wanted in my device!
Please help!
  • chez_me83 Dec 11, 2008
    i formated my sansa and now when i try to sync music on it it just says error beside each song. I have no songs on there now and cant put any on it either.
    i have manual sync.
    windows media player.
    other mp3 players work on the computer but not my sansa.
  • oxlizzie Dec 11, 2008
    it says it syncs one, then the next song says error and the next freezes my sansa.
    i turned off antomatic sync, i'm not completely sure how to change it to manual sync.
    i have windows media player.
  • 8,596 Answers
Turn off the automatic sync option - change it to manual sync, and then you should be good to go. Change to manual sync first, and then reformat.
Posted on May 23, 2008
SOURCE:
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
Sansa is unable to synch new music and only has 5 "bad tracks" on it that I can't delete...
Two possible methods:
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 29, 2008 | SanDisk Sansa e250 MP3 Player
Mp3
format ur music player i the settings menu, this will delete all the music on the player, or plug in and delete off the playlsit on windows media player
Mar 12, 2008 | SanDisk Sansa Clip MP3 Player
Hey, sansa problem with media player 10
Try formatting the player again.
When you open windows media player it is probably showing the songs that you have on your computer not the songs currently on your sansa.
Feb 24, 2008 | SanDisk Sansa e260 MP3 Player
I need help
go to settings in the menu and change the USB mode to MSC
then plug into computer
now go to MYCOMP and wait for player to show up as a drive
rightclick on the player and choose format
Once formatted, unplug player to restart database
Look into your music and make sure you do not have any questionable files such as itunes music or any mp4
Jan 25, 2008 | SanDisk Sansa e250 MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Not working
change the usb type to MSC under settings. when you connect the player to the computer it will now show up us a harddrive. right click on the players icon and select format IT WILL DELETE EVERYTHING ON THE PLAYER. after that has been done it should work properly just sync all of your music back onto it.
Dec 24, 2007 | SanDisk Sansa e260 MP3 Player
Bad track !!
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa e260 MP3 Player
I need Help!!!
or
-Tha Mp3 Doctor
Aug 01, 2007 | SanDisk Sansa e260 MP3 Player
BAD TRACK FOR EVERY SONG
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
194 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
