Question about Pool & Spa
Keyway alignment Prolems aliging half circle keyway oh the shaft of a lawn mower
  • 333 Answers
Hang the key half way off of shaft thed slide pulley on. and tap with a hammer
Posted on Jun 02, 2010
Does a 19hp kohler have timing marks?
for the cam shaft yes it should have timing marks that make sure your cam shaft and crankshaft are aligned. the keyway on the flywheel ligns the flywheel up with its ignition cycle obviously but yes the cam has marks for the crank
May 02, 2015 | Garden
I stalled the engine by grabbing on to a tarp. Now it will not start
I would assume the mower deck was engaged, check the shear half moon key in the shaft and flywheel. they are made to shear to prevent engine damage. other than that, check all the safty switches that keep the mower from starting unless they are engaged.
Apr 01, 2015 | Mtd Yard Machines 38-Inch 12.5 HP...
Adjust ignition timing
There is no timing adjustment the flywheel is Keyed with a groove and so is the Crank shaft. The coil is mounted stationary so the timing is preset and should never be bad unless the Keyway broke and the Flywheel shifted.
If you hit something that caused the engine to stall abruptly then the keyway may have broken...Just replace the Keyway
Sep 01, 2013 | Briggs & Stratton Garden
How to remove silver cover on front of engine
Bumped a tree and the mower died ?? If so, you broke the Keyway on the flywheel which threw off the Timing. Flywheel has to come off and a new keyway ( very cheap) has to be installed.
Aug 24, 2013 | Husqvarna 21" Lawn Mower with Honda GCV160...
If the key on flywheel is broken will shaft on mower still turn
yes it will its on tight, they are easy to remove though stick somthing under it to pry with now with a hammer hit the other side and top of the flywheel turn round and round till it pops off
May 12, 2013 | Mtd Garden
Does briggs&Stratton have shaft extensions to lower my blade 1in. or 2
are you sure you have the blade on the right way or the right blade for the mower?
Apr 01, 2012 | Briggs & Stratton Briggs Stratton...
My lawnboy lawn mower Runs Rough & Will Not Accelerate... What can I do to fix that?????
Your keyway might be cut. The keyway is the timing of your motor. If its cut, the motor will either run rough or not at all. If keyway is ok, check your blade for balance. Take blade off machine, hang on a nail straight across, if it tips either way, its out of balance. Have it rebalanced or replaced.
Jul 08, 2010 | Toro Lawn Boy Self Propelled CARB Walk...
5 hrspwr front tine tiller shears crank shaft key when fires..upon starting
What can cause this is a very worn crank shaft keyway, a loose flywheel nut or a worn out flywheel keyway. These are the only causes for a flywheel key to shear. If the crank shaft keyway is excessively worn there is no amount of flywheel nut tightening that will stop the flywheel key from shearing. The only fix at that point is replacement of the crank shaft. The same thing goes for the flywheel keyway... It is worn out the only remedy is flywheel replacement.
The only other thing that causes flywheel keys to fail is a sudden stoppage of the engine. Most of time this only happens to lawn mowers then the operator hits something like a mini tree stump or a large rock.
Thanks for using FixYa,
Kelly
I have seen both the crankshaft and the flywheel keyways worn to the point that both had to be replaced. In the event that both have failed, the replacement cost with labor if you have it done is a repair shop can be 60 to 70 % of the cost of a new engine.
May 01, 2010 | Garden
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
