Question about E-Flite Blade 400 3D RTF Electric Mini Helicopter
Throttle Problem When I start to push the throttle up the blades start spinning but after after 1-2 seconds the blades stop and wont work? All the servos work and i cant find anything in the manual that may cause this problem?
  • 748 Answers
Hi
Your ESC is sensing an error. The error is either blade speed or a peripheral device - possibly servo or gyro. Sub the servos one by one. Check the blade tracking. Have you had any crashes lately? You should double check all the head assembly components.
Posted on Jun 03, 2010
Ryobi weedeater throttle not working
Check the throttle cable connection at the carburetor throttle linkage, it (cable) may be broken or the carburetor linkage is broke.
Jul 09, 2016 | Ryobi Garden
Stihl hl95, 100
Is the 'cutting head' in a work position and not folded back.? Does the drive shaft spin.? Is the attachment on the shaft properly.?
May 02, 2014 | Stihl Garden
2008 Husqvarna LGT2654 Idles high and bogs with deck engaged
Hi, basically the bottom case will have to come off the motor again as your friend has failed to correctly position the governor gear against the governor arm, sorry Phil.
Jun 14, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
1995 camaro- the gas pedal is hard to depress when starting from a stop. i believe the problem is the accelerator cable but not sure
Hi
1) If the gas pedal is hard to compress you could have a broken spring inside the throttle housing. The throttle housing is located in the sealed compartment of the cruise control housing.(The housing with the rubber bladder.) You will have to remove the rubber covering to inspect the inner workings of the throttle mechanism. If every thing looks intact push on the accelerator. If it is still hard to push in, you could have a rusty cable.
2) A simple can of WD-40 should be applied lightly to the inner workings of the housing parts.
Try the throttle again and if it is still hard to push, check the connections of the cables to the throttle apparatus. Use the long plastic tube on the spray nozzle of your WD-40 can to shoot lubricant in to the small openings of the cable sleeve.
3) It may take a few minutes of manipulating the throttle to loosen up the corroded cable connections. Once the cable slides and the throttle seems to move freely take a dab of Vaseline and coat the ends of the cable connections. Vaseline will keep the moving parts lubricated and protect the connections from becoming more corroded.
4) By lubricating all moving linkages, you can prevent further throttle sticking. Make sure you replace all coverings back to the way they were when you started. Sit in the drivers seat and push the throttle pedal a few times to ensure that the throttle is no longer sticking.
5) Take your car out for a short spin in a unpopulated area such as a empty parking lot. Start and stop the vehicle numerous times to check it out. If the gas sticks at a slow operating speed, you can simply put the car in to neutral, apply the brakes and switch the ignition off. It is always better to be safe ..
However for an easy solution check cable to throttle body, it may be kinked. This is a common problem. Remove the throttle body and clean the throttle plate with a throttle body cleaner. Clean the front and back of the plate. Just spray and wipe off with a rag. Do not scrub with a wire brush. Doing this can damage the throttle plate. You can buy throttle body cleaner at most parts stores. Make sure you clean up your IAC valve while its off, that thing gets gunked up bad after a while.
Please check the link to remove throttle body in your car:-
http://www.ehow.com/how_4576010_clean-throttle-body-car.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 10, 2011 | 1995 Chevrolet Camaro
I have a Syma s032 that had its motors brushes distroyed in few flights. How to avoid premature wear? Is there another kind of motor that can be used on it? Thanks
You need to quickly throttle (left joystick) all the way down whenever you're about to crash or blade strike. Both motors have clutch to spin freely when in neutral. They will bounce off of anything if they can, i.e. if your hand isn't still pegging the throttle. But, if the blade (or blades) hit something that stops them while throttle is still being applied, one of three things will happen.
1) Blade will stop abruptly, putting grossly abnormal strain on the motor and those tiny little brushes inside. Motor may burn out. Every fraction of a second that throttle is being applied while blades cannot move, irreparable damage is almost certainly being done to the motor(s).
2) Blade(s) will break, maybe taking gears or shaft along for the ride.
3) or sometimes nothing seems to have happened, bird clunks to ground, you right it and continue flying.
however, if you throttle fully down, the motors engage clutches automatically and are effectively in neutral, spinning freely allowing the blades to bounce harmlessly off of whatever.
Throttle down when accident nears, and your motors will last for ages.
Hope this helps,
r
Dec 05, 2010 | SYMA Toys industrial Syma S032 Ready to...
Open throttle to full. clutch wont enegage for 3 to 4 seconds
Try a new belt, it may look fine but can be polished and have no grip left.
Jun 11, 2009 | RTO 50cc Moped Scooter
Sticky throttle on 200 Chevy Astro
There was a recall on the throttle body blade on the 4.3 a few years back for the throttle body to stick in the close position. Yours being 9 years old makes me think that there not going to do anything for it but give you the solution to the sticky throttle blade.
The solution was to change the blade. You can try cleaning the throttle body blade by spraying throttle body cleaner in to the barrel of the throttle body. If you look down, you'll see the carbon build up and it may just need and good cleaning.
If that does not work, you can buy a new Throttle body blade which is only held on by two screws on the throttle blade shaft.
Start with cleaning the blade and throttle body with throttle body cleaner. Just follow the instruction and you'll be fine.
Keep me posted and good luck.
May 31, 2009 | 2000 Chevrolet Astro
E-Flite Blade 400 3D RTF Electric Mini Helicopter Logo
347 people viewed this question
Top E-Flite Toys Experts
Andrew Taylor
Andrew Taylor
Are you an E-Flite Toy Expert? Answer questions, earn points and help others
