Question about LG WM2077CW Laundry XL Front Load Stackable Washer
LG TROMM Model WM2077CW-mildew on rubber
I love my Lg front load washer-first time buyer. however i have to leave my washer door open to air dry as i have mildew on the rubber part of the drum, If the door is closed i find the washin machine sticks when I reopen the door. Any suggestions on why this happens or tips to remove the mildew? my machine is balanced and there is no problem with the water draing.
  • Anonymous Mar 09, 2009
    I have the same exact problem...
  • Anonymous Mar 29, 2014
    The round rubber covering at the front of the door opening collects water under the rubber flaps that doesn't drain and produces mold and mildew under the thick rubber flaps. Very hard to clean and unless you clean and wipe dry after every use, there is mold and mildrew. I am willing to replace the entire rubber sealer but how do I prevent this and clean the mold that is produced if I don't clean and dry after every use?
    President:
  • LG Master
  • 2,651 Answers
First and foremost you MUST use an HE detergent, HE(high efficency) is design specifically for fontloading machines.. and use little amounts of it, 2-3 tablespoons is all that is required to clean a full tub of clothing.
Jusst using less of regular detergent is not the same as using correct soap. the moldy smell and black filth when the front bellow is pulled back is actually residual detegent not being disovled in normal operation , all front loading washers are experiencing this issue, there is a new product on the market to help combat this problem and for the 1-2 months ive been reccomending no one has told me that it hasnt helpd. heres the link www.affresh.com
Posted on Apr 09, 2008
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
LG WM2077CW Front Load Washer Problem My LG Tromm model # WM2077CW is leaking at the bottom of the machine but not from the door. If you run your hand along the bottom front of the machine there is a seam...
MOST OF THE TIME IT IS A HOSE THAT HAS RUBBED A HOLE IN IT OR THE DOOR BOOT DRAIN HOLE. THE HOSE IS ATTACHED TO THE BOOT BOTTOM CENTER OF THE BOOT AND HAS A SHORT HOSE THAT RUNS BACK TO THE TUB..
Apr 25, 2017 | LG WM2077CW XL Front Load Stackable Washer...
Tub smells like mildew, how do i get all the sludge out from the rubber lining, no matter if I run the tub clean cycle, it does not remove any of the sludge!!!!
You need to manually wipe out the inner seal(lining) every time you finish with the washer. This is one of the main complaints with front loading washing machines. You also neep to leave the door open(ajar) after you finish washing so the machine can completely dry out inside otherwise you will get a buld up of mildew. Also run a dishwashing packet like cascade(yes the stuff for the dishwasher) when you run the clean cycle. It is the same as the expensive washing machine cleaning packets that the appliance servicemen from sears sells to customers.
Nov 29, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Rubber gasket removal LG Tromm front loader
We found there is three small holes on the seal right inside the door, check to see if they are clogged with soap scum and clean them out. Run a cycle of hot water and bleach. Then, after each use, leave the door open and let it air dry and this has seem to work.
Jul 06, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washing machine has AWFUL mildew smell
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
Musty mildew smell
It is the same with all the front load machines out there. I do a bleach load once a week and always leave the door unlatched. All washers always have some water left in them. You can also wipe the gasket down with a weak bleach and water mix on a rag it will help also.
Apr 18, 2008 | LG WM2688HWM TROMM SteamWasher
LG WM2077CW Laundry XL Front Load Stackable Washer Logo
1,118 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
