Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Canon IXUS 700 Ok could not get the battery door too slide open no matter what i did.Finally got fed up and took a file too it and snapped the lid off,took batt out recharged it. Put it back into cammy,nothing will work.does that batt door having any other purpose than holding it place.....and do these models have a lock too them,like if you pressed two buttons same time locking cammy?
  • 94 Answers
There is a switch that the door presses whren closed, without the door in correct position the camera will not start up.
Posted on Jun 02, 2010
Where is the memory card located?
The memory card slot is near the battery chamber. There is a small slot parallel to the battery chamber. Check the bottom of the camera. There is a door that can be slid outside to open.
Jun 14, 2015 | Canon PowerShot SD500 / IXUS 700 Digital...
Confused over which battery pack I need for Ixus 700
What are you confused about? This is the correct replacement battery.
http://www.buy.com/prod/replacement-nb-3l-li-ion-battery-for-canon-powershot-sd10-sd100-ixus/q/sellerid/16427119/loc/111/208166814.html
Mar 06, 2011 | Canon PowerShot SD500 / IXUS 700 Digital...
My canon ixus 75 is not turning on properly the zoom lense is stuck out and wont retract. When i turn it on it says "lens error reset camera&quot
OK, assuming the batteries are ok, the problem is within the mechanism for the lens being too 'binding' while it operates.
Sometimes, people put their finger on the barrel of the lens when it retracts or extends.
If you reset the camera and it still does this, the camera needs to be serviced by Canon.
http://www.usa.canon.com/cusa/online_repair_tracking/consumer/digital_cameras/powershot_sd_series/powershot_sd500?pageKeyCode=requestRepair
Jun 28, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Cant open the battery door on my canon sd1200is
There are two ways to open:
1) instead of using the thumb to slide, use your nail to put in the clevis to push side to open
2) or unscrew 6 screws to take the face plate and then, try to open.
Jan 23, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
How do I remove the battery door from my ixus 75? I need to replace it as it slides open and powers off the camera - the tiny catch near the hinge point has snapped off somehow. I can get a new door from...
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
Jul 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Stuck battery/ScanDisk card
Unfortunately, you have to force the battery door (very carefully) to open it, and find what is wrong with it.
It is more likely that when closed the battery door, it was forced and it slided out of one guide channels.
You need to practice a little bit before to try it with force (genlty but with firm force), but the only way to do it is slide the button to open it, and at the same time slide to the side and pull the battery door, everything at the same time. Try it until you are able to open it.
Using any kind of tool (such a plastic pry tool, a small screwdriver, etc) to force will leave marks in the housing, and it's very possible that the plastic locking tabs will break, causing that you will open it, but unable to close properly again.
Best regards,
Mar 10, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Canon Digital IXUS 70, Camera Blank
This really sounds like a potential CCD failure. To confirm, take a picture while the screen is black, then download to your computer to see if the picture is also black.
If so, it is difficult for the average person to replace a CCD, and should only be done by an authorized Canon repair rep. If still under warranty, Canon will fix this for you for free. If not, recommend calling Canon anyways and complaining (this should not happen in such a recent model camera). If you complain, and possibly ask to speak to a supervisor, you just might get lucky.
Here's the number:
1-800-OK-CANON
May 17, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Powershot SD200/Ixus 30
It sounds like your mode selector external slide switch is misaligned with the inner one on the circuit board. Would recommend simply opening the camera case to remove the back face so that you can inspect the inner switch. While you have the case removed, also examine the ribbon cables to make sure they're all nicely seated in their connectors.
Here's a couple guides to help you remove the case. Go no further than simply to remove the external case so that you can inspect the above. When reassembling, MAKE SURE that the inner slide switch is aligned with the external slide switch in the same position:
http://www.smashedhat.com/sd300repair/
http://www.iq9.com/blog/2006/09/08/canon-sd400-lcd-repair/
Finally, also make sure you that read the following, as there is a risk of electrical shock if you're not careful:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Feb 21, 2008 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
