Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Hayward flo pump motor repair - Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
  • Rich Jun 02, 2010
    What is the situation with your pool pump motor?
  • 640 Answers
What exactly is wrong with your pool pump? If it won't start at all, check for improper or loose connections, blown fuses or tripped breakers, and open your switches and replays. Manually check the rotation of your motor shaft. Make sure that there is free movement and no obstructions. If the motor hums, but won't start, check for obstructions and check the Centrifugal switch to see if it is stuck in the open position. If you have low flow, check pool pumps for clogged or restricted strainer/suction line and discharge line of filter. You could also have an air leak in suction (bubbles issuing from return fittings). Low voltage could cause loss of suction. Check for plugged or restricted impeller.
Posted on Apr 25, 2011
john224
  • 1378 Answers
SOURCE: Hayward Max-Flo pump: Need to separate pump from motor
Remove the back cover from the motor, lock the shaft in place, thread off the impeller.
Posted on Jun 14, 2009
  • 93 Answers
SOURCE: hayward filter problem
YOUR HANDLE IS NOT SEATING IN THE RIGHT POSITION THERE IS A SPROCKET UNDER HANDLE THAT MAY BE DAMAGED TRYSETTING HANDLE TO DIFFERENT POSITIONS SEVERAL TIMES IT MAY HAVE DEBRIS UNDER IT MAKE SURE PUMP IS OFF.TAKE HANDLE ASSEMBLY OFF AND CHECK SPOCKET
Posted on Aug 06, 2009
  • 64 Answers
SOURCE: I have a Hayward Max-Flo II pool pump and it is
The bearings have likely lost their lubrication and have failed. You may be able tot find a local electric motor repair shop to replace the bearings. It really is not a diy project. However, if you can't find a local shop to do it, most folks replace the motor.
Posted on May 29, 2010
  • 990 Answers
SOURCE: 2nd Hayward Max Flo 2 hp pool pump stopped working again!!!
More than the motor it is probally a bad seal causing the problem with the motor. All you can do is be sure it is installed right when you put the new one in and if you see water under the pump take it apart and install a new one. I live in AZ and the water will evaporate before it gets to the ground under the pump so here this can be a real annoying problem. We quite often will have to look for calcium left behind when something leaks.
Posted on Jun 27, 2010
  • 990 Answers
SOURCE: I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
Posted on Jul 19, 2010
Hayward power flo lx swimming pool pump is making a grinding noise
THAT IS A ABOVE GROUND PUMP AND THE BEARING ARE GOING BAD, ITS HARD TO FIND A SHOP THAT WILL WORK ON ONE OF THOSE PUMP-MOTOR SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING AND HAVE HIM LOOK AT IT TO SEE IF IT'S A FIXER OR NOT ? .JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA.. REMEMBER TO VOTE FOR YOUR FAVORITE FIXYA GUY
May 07, 2012 | Hayward Power Flo Lx 1 Hp Pool Pump Sp1580
My hayward 1 hp pool pump is smoking. Now can I fix it?
ya sure can, it will need a new or rebuilt motor, i want you to search for your local pool pump motor repair guy and have him replace, repair the motor click here to see HOW TO TAKE YOUR PUMP APART. its best off to let a expert do the swap, you can install the motor portion back into the plumbing part of the pump and save BIG $$$. remember to ask your rebuilder what you can do to prevent and extend the life of your motor
May 26, 2011 | Hayward 1 Hp Max - Flo Swimming Pool Pump
I have a Hayward max-flo ii pool pump and it is very noisy. I already replaced all seals because it was also leaking. Are the bearings the cause of the noise? If so how do I replace bearings?
May 15, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Turned off hayward pump 3/4HP to clean out leaf basket and when turned back on would not come on. The pump is a little warm, so do you have any ideas or suggestions?
Quite often it is the starter capacitor on the pump motor. Easily repaired or replaced by a motor shop or swimming pool service company.
Aug 11, 2009 | Hayward 1 Hp Max - Flo Swimming Pool Pump
Jun 10, 2009 | Hayward 1.5 Hp Northstar High Performance...
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
873 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
