Question about Car Audio & Video
Amplifier Q..i switch out my 1500 watt fasgate amp for a 1800 watt nitro bmwx-5093.did i make the rite choice as far as performance?
  • slim noize Apr 09, 2008
    is nitro a good brand?
  • Andrew Hawkins
    Andrew Hawkins May 11, 2010
    I don't know what fosgate amp you have exactly, but you probably made a mistake. Some manufacturers test their max power output by just putting an enormus amout of power though their unit for a split second until it breaks. So always look at the rms values. I just looked it up on ebay and it said @ 2 ohms it will have 430wattsX1channel. A good rule of thumb is check the fuse value. So, far I haven't been wrong with it. To calculate power you take volts times current, so volts*current=power. A car's nominal voltage is 12volts not running. So, take the fuse/s ratings and multiply it by 12 and you will get approximate max power output. For instance I have a Memphis 2500watt amp. It has an external 250A fuse so 250*12=3000. I know that my amp is capable of well over 2500 watts. But this only works with the fuse value that came in the amp. If you up the fuse amp value you won't up the power out, you will just blown something. I hope I was able to help and not confuse you. Good luck.
    -Andrew Hawins
    Novelist:
  • 100 Answers
Actually I meant to post that as a solution instead of a request. Let me know If you would like to know more.
-Andrew Hawkins
Posted on Apr 11, 2008
Looking for the plug in harness for a Nitro bmwx 33.2 where can I get 8th?
BMWx-33.2W :: 3.2" Widescreen Head Units, Digital TFT ...
www.nitroelectronics.com > Car Electronics > Car Video
HEAD UNITS Digital TFT One DIN Widescreen 3.2" BMWX-33.2 By Nitro. ... Camera Input (without camera); 4 Channel High Power Output; Plug-In Harness ...
One Din with Monitor - NITRO-AUDIO
www.nitro-audio.com/one-din-with-monitor.html
BMWX-3.2 3.2" Digital TFT One DIN Widescreen/Touch Screen ... Plug-In Harness • NTSC/PAL System Compatible ... BMWX-33.2W 3.2" Digital TFT One DIN ...
NITRO BMWX 5393BT Car Stereo Bench test - YouTube
? 1:36
https://www.youtube.com/watch?v=PHjoXd55mTo
Mar 11, 2013 - Uploaded by colorado4wheeling
Looking online i couldnt find anything about this unit , except for the stock ... Looking at the devic ...
Dec 09, 2015 | Cars & Trucks
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
What size amp should i get for performance teknique sub-woofers
the amp you have will do the job depending on how may ohm you sub is and can you amp stable to handle low ohm's. you should also check your cabling to make sure its for about a 1500w amp so you dont lose any power
Sep 17, 2009 | Nitro BMW-482 Car Audio Amplifier
I bought a vehicle that has 2 nitro amps installed in it and the sound is crappy... i need the installation instuctions for the following.... BMWx-486 BMWx-483 help,help!!!
dude buy a new system for one never heard of a nitro and for two if you dont know **** about systems and your buying a beamer then you should have enough money to get a new better system installed
Aug 15, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
