Question about Jandy Laars Lt 250,000 Btu Heater
Heater will not fire. Fan comes on for a few seconds & shuts off. code on control panel is AIR FLOW SW. Heater worked fine until Sat. delivery of LP.
  • 33 Answers
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
LAARS LX250N-L error code AIR FLO SW and sometimes a HI LIM SW cannot locate the source of the problem?
hi limits are located under where the pipes go into the heater if corroded replace if wires bad replace to test you can jump them at the board only testing if left jumped heater could catch fire
Jun 29, 2015 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Why is this pool heater making a very loud whistle sound after heater is fired up?
could be the fan motor or check to see if a rust hole is giving you the whistle
Aug 28, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
Lound vibration when running
Check gas control valve.
Good luck,
Marty
Feb 18, 2013 | Rinnai Water Heaters
Rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Jul 04, 2010 | Solar Rheem Gas Fired Pool & Spa Heater...
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
5 year old Laars 25,000 LX won't ignite.
The low pressure indicator is for the gas pressure not the water pressure. The heater won't ignite because it's not getting gas to the igniter. Check gas supply, if okay, check gas connections, valves, etc.
The 1 HP motor should be fine on the jacuzzi.
May 26, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
My r85 rinnai water heater vibrates significantly and makes
Sounds like there is something loose in the line.Like cut off valve,check valve.
Mar 09, 2009 | Rinnai Digital Remote Water Heater Control...
Reddy kerosine space heater
bucklehead...I assume you discarded the 2 year old fuel... if not do so. Your fuel delivery problem could be caused by a number of things. 1. Incorrect air pump pressure, 2. worn or restricted nozzle, 3. deteriorated fuel line or air line, which in turn is creating the ignition problem, 4. the spark plug is bad OR you may not have a fuel delivery problem at all - just a photocell that has gone bad or has a wasp nest built betweem the eye and the flame (check this first). If the photocell can't see the flame it will shut the heater down. That's it's only job.
More troubleshooting tips
Apr 11, 2008 | Scheu (K50-FA) Heater
Jandy Laars Lt 250,000 Btu Heater Logo
219 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
