Question about Yamaha 12V Air Pump
CANT START I NEED TO CHEK FUSE BOX FROM BATERY
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details of the problem
Thanks for using FixYa.
Posted on Jun 09, 2010
Why the Batery and Break warning lights are always on?
did the car run good for 2 weeks? with the car running your voltage reg. should put approx. 14.6 volts if the system is charging. I would check all the fuses with a test light. Call your local dealership and they will tell what fuse is the charging system fuse.Make certain all the fuses are good first, then check both of your battery cables make sure their not corroded. if you still cant figure it out it could be a bad fusable link, also trace the wires off the alt. check for bad spots..good luck
Aug 19, 2012 | 2004 Kia Sorento
I have a 2004 Kawasaki zzr 600 that does not keep the charge longer than 2 days. What is causing this problem
hi, you probably have a "almost dead" batery, but in order to properly check, proceed as folows:
1 - give the batery a full charge
2 - disconect both cables (+) and (-) from batery
3 - check charge and see if batery holds it - a good batery must keep 12,7 to 13,2 volts for a very long period
If after this test,considering that batery is ok, then chek your wiring loom for ground losses
good luck
Sep 13, 2011 | 2004 kawasaki ZZR 600
95 mercury marquis ignition switch pin b5 is missing 12 volts- where does it come from?
B5 - 276 Brown - Switch Feed
Fuse 1 (15 amp) & Fuse 10 (10 amp) in the IP fuse box.
And, 50 amp Fuse in engine compartment fuse box. behind batery
please rate, thanks
Jun 27, 2011 | 1995 Mercury Grand Marquis
My sons 2005 santa fe coolant fan does not come on after vehicle has been on. Is there a censor that could not be working?
Hi you can start by chek the coolant fan fuse and the conection for corosion . Allso you can chek at the fan un plug the pluging pout a jump willer wit a 10 amp fuse at the fan plugin at 12V and a jump willer at ground sid at the batery and fan if fan works fan is good if fan dos not work riplas fan. Allso you can worm up the car at normol oporation and test at fan conecter not the fan sid wit test light if light dos not com on the temperateur senser is folty riplas TMPS .
Jan 20, 2011 | 2005 Hyundai Santa Fe
1999 Pontiac Bonneville headlights do not come on. Can't find fuse for headlights. Fob no longer activates door locks. Help.
THERE ARE 2 FUSE BOXES, 1 UNDER THE HOOD & 1 INSIDE THE CAR. TURN ON IGNITION SWITCH TEST EACH FUSE WITH A GOOD FUSE TESTER. FUSES CAN BE TESTED WITHOUT REMOVING THE FUSE FROM THE FUSE BOX. THERE ARE TEST POINTS ON EACH FUSE FACING OUT. POWER ON ONE SIDE OF THE FUSE, FUSE IS BAD. POWER ON BOTH SIDES OF THE FUSE IT'S O.K.
Jan 01, 2011 | Pontiac Bonneville Cars & Trucks
Batery wont charge new alternater and batery the batery light does nont come on in the dash
Check the 30 amp alternator mini fuse (#26) in the engine compartment fuse box by the battery. By the way, if you don't have an owners manual, you can download on here: http://www.motorcraftservice.com/pubs/content/~WOVSAB/~MUS~LEN/40/97sabog1e.pdf
Dec 04, 2010 | 1997 Mercury Sable
Start an engine that has not run for 6 months
chek the plugs clean up your fuel system reload your batery and then start
Nov 15, 2010 | 1983 Ford Escort Gt
I had the same problem
chek d batery or try to re pormat
Jul 19, 2009 | Nokia N96 Smartphone
I chek the volts on the batery and is only 10 and i do chek the generator and is only 9 volts have to change the generator
charge the battery real good and start the bike rev it up to 3000-5000 rpms and see what kind of volts you have if its over 13 your good if not have the generator checked you might get lucky and only have to replace the rectifier in the generator
May 15, 2009 | 2003 kawasaki ZX-6R
My Emachine W1700 won't turn on.
1/chek power cables
2/chek power supply box u might neet a new one cuz the fuse inside it might be blowed
3/chek if ur power button works well
4/try another outlet
5/see if some one chnage the voltage in the rear of ur machine
hope that would fix ya
foolow me rate me
Aug 15, 2008 | Computers & Internet
Yamaha 12V Air Pump Logo
59 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
