Question about Kenmore Washing Machines
Kenmore elite oasis top washer washing towels. heard noise. -- on display panel. can't open door. ordered new control panel installed. it make 3 noises like test of water going in and then door unlocked. but still has -- on display and nothing else unplugged for 30 mins same thing happened.
  • Kenmore Master
  • 12,061 Answers
Http://www.servicematters.com/maytag_library/docs/16022937.pdf
http://www.washerhelp.co.uk/diy-repair-help.html
Hi, well to have any chance of a repair you absolutely need a service manual, I have found one above, also please find a self help DIY troubleshooting and repair website that with the manual, you should be able to quickly, isolate and remedy your issue. Please perform the troubleshooting procedures in the manual, and you will be able to isolate and remedy your issue.
Posted on Jun 02, 2010
  • cjmac01 Jun 02, 2010
    cant do test.... will not get off the dash dash on screen. read manual. gives you all the F problems
    but nothing about a dash dash. got manual that came with the washer. got a test manual off the web. after i plug it back in and it makes the 3 sounds. like water going into washer. but. nothing coming out of washer. do you think it might be clogged? and it stops after it tries to cycle.
    i know the water is on. going to the washer... moved the draining hose lower. incase it was to high.
    but it has been like that since we got the washer in 2007 last year sears came and replaced the control board.. but i jsut replaced it with a new one. all it did was unlock the door. and start of a test cycle i think.
    Jun 02, 2010 - cant do test.... will not get off the dash dash on screen. read manual. gives you all the F problems
Door won't lock on top loading kenmore elite oasis washing machine
1. Disconnect the electrical cord from the wall.
2. Move the washer forward about 12 inches.
3. Lift the lid and grasp the front of the washer top with both hands.
4. Place your knee on the front of the cabinet and pull the washer top forward and up.
The lid lock mechanism is secured to the bottom of the washer top with two screws. Remove those screws and the wiring will be exposed. Unplug the harness from the old mechanism and connect to the new one.
Secure the new mechanism to the washer top and let the top down.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Du error code on a kenmore elite oasis he what does it mean and what can i di to fix the problem
Door unlock failure
Excessive force on door lid is preventing lock bolt from
retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an
unlocked state. See TEST #8, page 14
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Elite Oasis™ 27052 Top Load Washer: It just stopped with Ld flashing. There is water s...
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the Cabinet....
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
May 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE washer dislays Ld error. Any ideas what is wrong?
5
6
7
Apr 27, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have Kenmore Elite top-loading washer that will not agitate or spin. told it is probably the coupling between motor and transmission. can't get control panel off.
5
6
7
Apr 24, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Need to disassemble a kenmore elite oasis dryer
5
6
7
Aug 03, 2009 | Kenmore Elite Oasis ST 6806 Electric Dryer
Bleach spots
Likely the washer bleach dispenser - closing early - or the door has warped - so it does not shut all the way after the call for bleach.
You'll need to inspect the bleach tray - and make sure it operates normally.
5
6
7
Apr 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
How do you open a Kenmore Elite Oasis top-loading washer?
I just finished installing my new control unit for my Kenmore Oasis and my F1 problems are GONE! I ordered it from Sears Direct Parts. With shipping and taxes it came out to about $174 for the part, but our issues are gone and now we can wash a load of clothes without having to reset it several times.
Mar 18, 2008 | Washing Machines
Washing Machines Logo
16 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
