Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Water not coming out of the water dispenser on front door of fridge
    Scholar:
  • 44 Answers
Probably need to replace the water inlet valve on back bottom right of refrig.
Posted on Jun 05, 2010
At back of unit I disconnected line and get water and I know that the switch works but no water comes out front?
When you push in the water dispenser do you hear two clicks? The first click is the switch in the front. The second click is the solenoid in the back. The solenoid has to open to let water through. If you don't hear that second click then it is most likely the solenoid.
If you remove the grill below the fridge doors you will find a plastic line and a coupling. disconnect the coupling. Push the dispenser arm in and see if water comes out. If it does then you have a frozen water line in the freezer door. Most likely it is frozen right below the ice cube dispenser door as it sometimes leaks out cold air if it does not shut properly. You can use a heat gun or hair dryer to thaw the line. Be careful not to melt any of the components.
If you do not get water out of the line at the coupling then it may be frozen in the fridge cooling coil. This is rare and usually only happens if you run your fridge on a very cold setting.
Jan 24, 2011 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
Water will not come out of dispenser
Remove kick plate at bottom of fridge in front. Find line that brings water to door. There should be a coupling that connects the line together there. Remove the line and get a cup. While holding line into cup with door shut push water dispenser with other hand. Did you get water into cup.
Report back
Nov 13, 2009 | GE GSS23SGSSS Stainless Steel Side by Side...
Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Jun 15, 2009 | Maytag MFI2568AE Side by Side French Door...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Fisher and Paykel fridge buttom freezer with water dispenser
Please advise where the dispenser is leaking? If it is dripping out the front of the door, then I suggest you run the water dispenser to flush about 3 liters of water. Does the noise stop when you open the fridge door?
Jul 01, 2008 | Fisher and Paykel Active SmartĀ® E522BR...
Frigidair frs22zrf side by side w/ front ice and water
From what you are describing, it sounds like you need a valve. Another common thing I run into is the cooling tank inside the fridge freezing. This will usually affect water through the door only. Remove the crispers and you should see a large coil of plastic water line attached to the back wall of fridge. You can check to see if it is frozen by blowing through it from the end of the line you removed from valve. BEWARE, if you blow through it, water will come out dispenser if line is not frozen. Have a towel at front of fridge.
Oct 03, 2007 | Frigidaire FSC23F7D Side by Side...
No water at the door 2
hesshouse ---- thanks for the tip. I only had to leave the light on in the dispenser for less than 5 minutes and the water's running fine now!
Dec 02, 2006 | GE GSL25JFPBS Side by Side Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
142 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
