Question about Samsung Syncmaster 2033SW Monitor
Samsung Syncmaster 2033 monitor. I turn it on but nothing wont show just the words ''analog'' then ''digital'' the only thing blinking is the little blue light under the samsung logo.
  • Jorge V Jun 02, 2010
    thanks!!!!! just added Geo drive graphics card...forgot to put the cable on the graphigcs card. thanks a million
  • 776 Answers
HI,
Tere could be couple of reasond due to which this issue comes up:
First and the foremost issue looks like a driver issue. You might try reverting the driver back to the previous state and see if you can get your picture back up. If you dont remember the settings try running the CD again that came with the monitor and upload the drivers again.Also, you might want to check to make sure you're displaying in resolutions that the monitor can support.
I would also like to inform you that the monitor should have come with two cables. One is for analog and the other is for digital and is rectangle. Before turning on the computer connect only the Digital cable to your monitor and the video card on the computer. Most of the monitors sence automatically the Digital signals and start operating when you start up the computer. Make sure the monitor is on when the computer starts. Your manual should have instructions that will help.
Do not conect both the cables together as only one is needed.
You also might want to tryTry using theauto-adjust feature on monitor. If that does not work, try booting in SAFE mode. It should boot completely but at low resolution. Try increasing resolution then reboot to normal mode. Also try updating your graphics driver.
Posted on Jun 02, 2010
How do I turn off the Samsung sync-master p2050 monitor?
If it doesn't turn off by holding the power button down for 10 seconds, then it cannot be turned off by the power button alone, like most modern lcd monitors. Most modern monitors goes into standby mode. To completely cut power, you must unplug the power cable.
I've enclosed a link to the install manual for reference.
Samsung SyncMaster P2050 User Manual Page 7
Nov 24, 2014 | Samsung Computers & Internet
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
I bought my samsung 2033 a month ago. It recently has started to turn itself on and off. Also occasionally no effect when trying change channels.
I have to send mine back to Samsung because of the same problem. Samsung is now like Toyota not disclosing know problems.
May 20, 2010 | Samsung Syncmaster 2033SW Monitor
Syncmaster 2033SW Monitor: I bought my samsung 2033 a month ago. It recently ...
I would take it back right away, when electronics break down in lees than 6 months it is not a good sign. Get the replacement or have it fixed under warranty.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 18, 2010 | Samsung Syncmaster 2033SW Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. The images show for a few seconds and goes blank...turn monitor off and on...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 15, 2010 | Samsung SyncMaster 204BW LCD Monitor
The monitor powers up and the analog icon blinks on and off and nothing else happens...no colors...when connected to computer.. the images show for a few seconds and goes blank...turn monitor off and on...
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 29, 2010 | Samsung SyncMaster 204BW LCD Monitor
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung Syncmaster 2033SW Monitor Logo
380 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
