Question about HP Compaq iPAQ MP4800 Multimedia Projector
Compaq mp4800 will not turn on, standby light comes on but when I press it will not go to green light
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Tv switched itself onto standby and now will not turn back on. tried unplugging it and plugging it back in but it still won't come off standby. when you press the button on the remote it goes green for a...
unit seems to go into protect mode.Theres very little that can be done..There is good chance unit needs to be checked at a repair shop.Try to find one that is authorized for your particular brand if possible
Aug 05, 2009 | Televison & Video
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Computers' power light is blinking and will not power on
This normally means that the computer is in standby mode all you need to do is press the power button. If this does not work then hold the power button in for about 10 seconds until the computer turns off then wait a further 10 seconds and turn back on and boot normally.
Please let me know it this works and please rate me. Once you booted normally set the power options within control panel not to go into standby.
Cheers J
Jan 01, 2008 | HP Compaq Presario S3000nx (DC475A#ABA) PC...
Unable to turn on computer
was the computer on standby when you plugged it out?  press and hold the "on" button for 5 sec's this should switch it off and reset then try turning it back on again by pressing the same button
Oct 31, 2007 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Greenish display
Had the same problem. Opened the cover and find out that when I press the part above the lump the display become normal. Some loosed connector was my first thought. But, after a while looking and pressing around found out that the cover of the lamp was not placed properly and one corner side of the lamp cover was displaced. Opened it, returned it back to fit properly and the green display is gone. Hope that will not appear again and that is the same "problem" with yours.
Aug 12, 2007 | HP Compaq iPAQ MP4800 Multimedia Projector
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
HP Compaq iPAQ MP4800 Multimedia Projector Logo
50 people viewed this question
Seeker5211
Seeker5211
