Question about Dishwashers
I need instructions for d3121
I need manual for my asko dishwasher
    Sergeant:
  • 351 Answers
Look up asko.com.au,
Posted on Jun 02, 2010
Our 4 year old Asko D3121 dishwasher has stopped heating the water and drying off the dishes..is the problem as simple as replacing the heater element ??? If so ,how difficult is it ?
I would check the voltages around the heater before replacing it. Sometimes the thermal overload relay opens out and shuts off the power. Could be a more simpler to replace than the whole heater.
Jun 29, 2010 | Asko 24 in. D3121XL Free-standing...
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
D3121 has standing water in bottom of diswasher; have cleaned filers stil ge t standing water
check that the outlet hose is not blocked. or maybe there might be somethink stuck in the pump.
Jan 24, 2010 | Asko Dishwashers
My diswasher does not drain properly and the cycle is block How to get out water manually I have ASKO D3121
The ONLY way to get the water out is to bail it out and then soak the rest up with a large towel. Not a pretty solution, but an honest answer. I hope this helps you!
Aug 14, 2009 | Dishwashers
Asko D3121 Dishwasher - won't dry dishes
Has anyone found a Fix for this one yet????
I have the same problem Dryer fan (Turbo Fan) in the door not working.
Apr 06, 2009 | Asko 24 in. D3121XL Free-standing...
ASKO dishwasher won't drain and makes rattling sound.
I had tried several failed attempts to fix this problem. Finally I got on my knees and asked God to make the dishwasher run in Christ's name. The dishwasher just completed it's first cycle without any problems.
Feb 10, 2009 | Asko 24 in. D3121XL Free-standing...
Pump is always running on my Asko D3121 even when door is open. the pump works OK when I put water in dishwasher but never stop
check the float switch ... it is under the dishwasher it could be stuck in the up postioin or you can have water under the dishwasher..
Hope it helps....If NOT let me know more about your problem ... I will Help
Nov 16, 2008 | Asko 24 in. D3120 Dishwasher
Model d3121 does not "heat"... when I use it the water don't be hot and the dishes doesn't dry. you can answer in french i'll try to understand ... as you can see i'm not bilingual but...
In my case, the problem was with the control card, located behind the control buttons on the front. The relay driving 120V, 10A to the heaters had one pin dissoldered, probably because of heating. It was dark around the pin. See the picture attached. The top part showd the PCB with the faulty pin marked by a red arrow; the bottom part shows the other side of the PCB with the relay itself.
Remember that this relay/pin drived 1400 W.
I found the electrical drawings here:
http://www.greatplainsapplianceparts.com/order/Parts%20Manuals/Asko/ASKO-Dishwasher/D3121%20%28DW20.1%29%20SS.pdf
Oct 01, 2008 | Asko Dishwashers
Dishwashers Logo
162 people viewed this question
Top Dishwashers Experts
