Question about Samsung 50 in. Plasma TV
I have a Samsung 50" Plasma,clicks on and off.
I have a Samsung 50" S50HW-YB02 Plasma TV. First the screen went blank, but I still had sound. Found a bad fuse, replaced it, then it just clicked on and off. Found a refurbished PSB, installed it, but had the same problem. Do you have any suggestions?
Chris George
Hi, i have the same tv with the same problem, did you by any chance get yours' working properly again? if so, could you please tell me how you did it.
Posted on Feb 04, 2011
I want screen. tv samsung
Posted on Nov 08, 2011
  • Samsung Master
  • 12,061 Answers
Http://www.coit.uncc.edu/coit_new/techsupport/Plasma_Documentation_files/PPM50H3QX_EDC%20D62B.pdf Above is your service and repair manual for your set. www.scribd.com/.../SONY-KDL42XBR950-TV-Plasma-Training-Manual above is a Plasma TV trianing manual, Shows you how they work, nost info is translatable between sets. www.scribd.com/.../LG-TV-Plasma-Training-Manual - 3 hours ago Same above another training manual. Hi, well I applaud you for wanting to have a go, but you must make sure that you are starting in the right place, That is The Power Supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. That’s it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then that’s a prime cause of failure. Resistors, hardly ever go faulty, and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be able to say.. "Oh that’s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish, a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins. The Tools you will need are A SERVICE MANUAL a Good Multimeter, a Signal generator, a Signal Tracer, pref an Oscilloscope, Soldering Iron, De-soldering iron, Probably, too, A SMT Hot Air desolderer (for the Surface Mount IC's), Compressed Air, An Anti-Static Wrist Strap, (MOST IMPORTANT, to prevent ESD), Cutters, Screwdrivers, sometimes, Torx, drivers too. Tweezers, are real handy, a magnifying glass, or eyepiece, a good strong white Light. OH, and you MUST have the original remote control too, (Sometimes one must obtain, purchase, a special “Servicing remote”) as one needs this to "Program" the Computer in the TV, after, and during servicing, and to be able to put the TV, into "Service Mode" too.
When servicing try not to let the entire thing overwhelm you as one, treat the set as a conjunction of “Units”. Meaning that we can break the unit up into sections, for instance we have a Power Supply, and Audio section, a Remote Control section, we have a Input Control section, we have a Video Control section, and so on. Now all these connect to specific parts of the circuit. Some have no relationship with each other and some are dependent upon each other. What we need to do is try to understand our “Fault” and isolate it to at least an “Area”. Now when we have isolated the apparent problem, we then need to check our “Input” to that section and also the “Output” of that section, also we must first check that sections supply voltage and current, are correct. Depending on the unit being serviced, the Repair options, may be limited to changing a “Board” to clear the fault. Often these boards are exchangeable, and you get a rebate back, if when you purchase the new board, you send them you old broken board, and they then repair that, and around it goes. Other times, one must go down to “Board level” to effect a repair, always double check, before determining some component is faulty, it is best to isolate/remove, the component to test, often an “in situ” test can give erroneous reading due to “Other” components connected, altering the readings. Always replace with as good if not better components that you are replacing, skimping of component costs is counterproductive, in the long run. It can often be a great troubleshooting method, to completely isolate the “Faulty” part of the circuit, if you can, isolate the in & out, and also remove, the “Native” power from, it too. You power from and external source, then also you can provide an External “Drive” to this circuit which you will NOW, be able to test under a, “know good” situation, which is so important to gain a benchmark for operation. NEVER EVER simply replace a Board or Component without ascertaining WHY, it has failed, as seldom does anything spontaneously fail, unless placed under stress at all operating times, such as a power Supply or the like.
Posted on Jun 02, 2010
A Samsung 50 inch model s50hw-yb02 plasma tv
Please provide more details about the problem you faces with this TV. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 16, 2016 | Samsung Televison & Video
My S50hw yb02 has power but does not display picture. It when pop I see the blue light on the on off button I then turn on as normal but no picture?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 07, 2012 | Samsung 50 in. Plasma TV
We have a Samsung PS50Q91HDX Plasma Tv which is not quite 3yrs old. Ever since we have had it, it turns itself on & off at random but this is not the main problem. Last night we were watching a show...
This is weird. I also have a plasma 50" model PS5Q91HDX and on the 5/02/11 the screen went blank when my friends daughter was watching a Wiggles DVD. The image kept coming back, flashing a scene or two before going black again. But the sound is perfect.
I wonder what is going on? Is anyone else having trouble with their 3-4 year old Samsung 50" TVs???
Jan 17, 2011 | Samsung Televison & Video
I have a 50" plasma that I replaced in a home. It came with a jbl cinema system, it only has a dvi like plug on it and no other inputs. I opened it up and it has a s50hw-xb02 plasma screen in it I looked...
Just a DVI like plug(HDMI) and no other input , just a couple of boards. That doesn't sound like a tv to me. Most plasmas will atleast have a component/s-video input!
Aug 18, 2010 | Televison & Video
Screen went blank but still have audio
loud pop then no picture. still has sound 50 in samsung plasma mod s50hw-yb02
Feb 24, 2010 | Samsung 50 in. Plasma TV
50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Sep 02, 2009 | Samsung LN-S4051D 40 in. LCD Television
While watching TV screen went blank. Voice stayed on
the photon charges at the back of the tv might be damaged, try to take it in to be repaired if not i suggest u buy a new one, please, please, please do not take it apart to fix it urself, alot of bad burns have happened to people who try to fix plasma tv's.
Apr 12, 2009 | Akai 50 in. Plasma TV
Lg 42inch plasma
Sounds like main board failure and or power board failure. You need to contact manufacturer and describe problem for tech support. Some of the parts in Samsung TVs have lifetime warranties. Change out of two board is about an hour job and service call is usually comped. Hope this helps. J
Apr 09, 2009 | Samsung HPT5054 50 in. HD-Ready Plasma...
Samsung  50 in. Plasma TV Logo
3,113 people viewed this question
Jerry Greenberg
Jerry Greenberg
