Question about Kenmore Refrigerators
Outside control panel (ice/water) linking and making noise and cannot be stopped. can i turn off the control panel temporaily and still keep the refigerator/freezer plugged in?
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.com.
Start by checking voltage at the outlet to see if you have proper ground .It is suggested to remove the front panel circuit board.And still if it doesn’t solve the issue, you need to replace the motherboard.Check your model and confirm with your dealer as to where the mother board is located.Most probably you have to pull the rear cover over the compressor and on the left side should be a plastic box inside this box is the” MOTHER BOARD”.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on Jun 02, 2010
Why has it stopped making ice?
Usually, the filter on the fill solenoid has failed,
and the valve is jammed open with a piece of trash, grain of sand, etc.
Other possibility, the water level control has failed.
Jul 24, 2015 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Rs2556sh no ice or water
Hi Ken Wolter, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Tell me more about the cooling or not cooling at all? Can you feel the top of the compressor and tell me is it warm, cool or too hot to keep hand there? Are the fans running inside and outside? Lights on and control panel working? any clicking noise from the compressor? DA35-10013Q Start Relay and DA34-10003S Overload, let me know, John Tripp Appliance 911
Feb 20, 2014 | Refrigerators
Turn on water light on outside of door
Can be faulty control panel causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Maytag Refrigerators
Control panel
Its faulty control panel, needs to be replaced.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
Not making ice, making a loud humming noise its a top freezer RT18BMXBL01
The ice maker has completely stopped producing ice:--Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly :--When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Noise can come from these areas:
The inside of the freezer :--Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator:--There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator:--Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
This will help.thanks.
Feb 21, 2010 | Roper Refrigerators
There is a smell from outside the frige
check drip pan for smell see if ice maker lever switch is up for noise
Mar 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice and water dispenser not working
ALWAYS MAKE SURE YOUR APPLIANCE IS UN PLUGGED BEFORE TRYING ANY PROCEEDURES !!!!!! MAKE SURE THE WATER SUPPLY VALVE (SOMETIMES 1/4" SADDLE TYPE PEIRCING VALVE) IS NOT CLOGGED WITH SEDIMENT... THEN MAKE SURE THE WATER SOLENOID IS NOT CLOGGED AS WELL ... THE WATER SUPLY SOLENOID HAS A SMALL ORFICE THAT CAN BECOME PARTIALLY CLOGGED OR DOES NOT "SEAT PROPERLY" AND CAN CAUSE INSUFFICIENT WATER SUPPLY AND THUS ERRATIC OPERATION. A LARGE PERCENTAGE OF WATER DISPENSER AND ICE MAKER PROBLEMS ARE DUE TO INADEQUATE WATER SUPPLY. IT IS THE FIRST THING THAT NEEDS TO BE CHECKED !!!
Apr 26, 2007 | GE GSH25JFR Side by Side Refrigerator
Outside door light won't turn off
Please post the model number so I can pull up a schematic. Some models have a "night light" mode that may have been activated so check the owners manual, other than that the control board could be bad, providing a slight "leakage" of power to the lamp (depending on the type of lamp control circuit).
Dec 27, 2006 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
14 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
