Question about Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher my dishwasher circle is taking forever to finish. what should i do?
  • robert samples May 11, 2010
    try turning all options that use heat hi temp wash hi temp rinse heat dry then run it again and let me know what happens
  • 48 Answers
Set it to clense it cleans just as well but its much faster.
Posted on Jun 26, 2008
The green clean light wont go off when cycle is finished unless door is opened then shut again
Mark,
That is normal with most dishwashers. Mine at home does that.
Jun 12, 2015 | Dishwashers
Cycle takes forever also not heating
On the side of the units there is a matrix (up and down tubes ) they need cleaning but I will warn you the pipes from the drain and through the matrix are gummed up with a disgusting sludge. There are some push on fittings and some held with spring clips take some photos when disassembling but it is easy just time consuming trying to flush the gunk
Sep 19, 2014 | Zanussi 24 in. DE6744S Free-standing...
My dishwasher takes water but does not start to wash it pumps the water out and takes new water and that's going forever
SOUNDS LIKE THOSE LITTLE ROACHES GOT INTO THE CIRCUIT BOARD AND FRIED IT.
MAIN CIRCUIT BOARD HAS BEEN SHORTED OUT
Apr 30, 2012 | NEFF S54T09X1GB Fully-Intergrated Full...
I have a bosch dishwasher shu6805uc/u06 to long to wash.
Well not going into the dry cycle could be a timing issue or a EOC (control panel) issue and will need to be addressed. But most dishwashers these days have a active run time during normal cycle of 110 to 120 mins, and thats not including the heated dry feature. I would let the unit run and see if it will finish on its own, and if I say it pushes two and half hours then something is wrong. A tech would most likely have to look at it, also a power reset could help but thats like a 30% chance.
DrakeTech
Dec 30, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
The most obvious failure would be the mechanical timer that is behind / part of the knob used to select the cycle.
But, you may want to inspect the heating element in the sump area -- some dishwashers will wait (and wait) for the water temp to come up high.
Good Luck!
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire FDB710LCS0 Dishwasher dial seems to stick?
I had the same problem. Turn the HIGH TEMP buttons off. Simply turning them off corrected this problem for me. Mine got stuck in two places and I had to manually turn the dials or the washer would run all night.
Nov 21, 2008 | Dishwashers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Stuck in rinse cycle
Mimmi, If the water isn't reaching temp this will happen. It sounds like a heating issue.
Guest,
The spray arm being blocked will not cause this. Again your machine isn't heating the water to temp.
Oct 27, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU53 Built-in Dishwasher Logo
46 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
