Question about Pioneer Audio Players & Recorders
I recently changed out my Motorola cable box for one with HDMI. After hooking it up to my 62" Mitsubishi (WD-62628) DLP TV and my Pioneer Elite (VSX-72TXV) with digital audio I can't seem to get any sound. I also use a Harmony 880 remote for everything. Is the problem in the remote, TV, or A/V receiver? Can you help me out?
SOURCE:
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
SOURCE: Need a user manual for my Pioneer Elite VSX-07TX
I have this manual and can make a PDF for you.
Posted on May 25, 2008
SOURCE: pioneer elite VSX-94txh freezes up
dont buy pioneer until they recall and fix problem ethically
Posted on Jul 27, 2008
SOURCE: Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Posted on Dec 10, 2009
  • 5 Answers
SOURCE: pioneer elite VSX-92txh freezes up and cannot be turned off
There is a fix for this problem
Posted on Dec 19, 2009
Hdmi inputs are not working on my mitsubishi WD65738 DLP
That TV is suppose to have automatic input detection but if it doesn't work you can press the input button on the remote and then use the arrows and enter to select the input you are trying to use.
Dec 12, 2013 | Mitsubishi WD-65738 DLP TV
Suddenly lost Laptop to Mitsubishi 60c9 connection using HDMI
never plug in hdmi when comp.is on you may burn your hdmi port
Aug 03, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
I am trying to connect my hp laptop to my '73mitsubushi tv with an HDMI cable. TV says wrong format. Help!
you have to select the monitor out on the computer is ether the f1 or f2 key on the laptop
Feb 12, 2012 | Mitsubishi WD-73638 DLP TV
I want to know what type of cable wire do you need to hook up for HDTV and where you hook it up at on the TV
HD can come from two types of cables. A RF cable, normally it is a RG 6 or maybe a RG 59 coax cable. A HDMI cable is the other method of obtaining HD on your HDTV. A HDMI cable has a rectangular shape with small pins, its about 1/2 inch wide by 1/8 inch in height. The RF connector is about 1/4 in circular. A HD signal can come from a cable box or it can come from a DVD or Blue Ray player. Google these type of cables and look on your TV for the connectors.
Jun 20, 2010 | Mitsubishi WD-62525 62" Rear Projection...
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines...
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62628 Mitsubishi DLP
Here is the picture for a Mitsu62525 power board, which is similar.
You recognise it because you get power cables innesting into the power board.
If you decide to work on your TV, get the service manual first.
Oct 10, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Wd 62628 tv
After I reset the system, the Audio menu gave me access to the TV speakers that had been turned off. I turned them on and had to wire audio cabes from my sat box to the component audio in on the TV.
Sep 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Random flashing streaks on screen
Check multiple inputs and multiple sources. Check your dvd player; does it happen there? If not, you are probably right to suspect the cable box.
When you are checking multiple inputs, you want to make sure that if your cable box uses component or HDMI, that you check your DVD player on the same style input.
The reason for this is that your electrical chassis treats the analog (composite, s-video) inputs different from the HD and digital inputs (component, DVI, HDMI).
If you try your DVD player and cable box on the same input and experience the same probelm, you probably need to have the electrical chassis rebuilt in order to fix a problem on the tv's FMT board.
Cost: $800+
Wait time: 4-8 weeks.
Sep 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mar 28, 2008 | Pioneer Audio Players & Recorders
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Sweetleaf
Steve Sweetleaf
Ben Armstrong
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
