Question about Saeco Royal Professional Espresso Machine
The automatic foam dispenser is not working properly, it sucks up the milk, bit does not producehot milk and foam.
  • 1 more comment
  • scoph Apr 20, 2008
    Do you have any other solutions to my problem, this one did not seem to work for me.
    Sophie
    My machine is being ungreatful to all suggestions would there be another, it stops the process itself when cant do it. (**** and produce hot milk and foam)
  • Anonymous Mar 23, 2014
    Milk capuciono foam
  • 81 Answers
Try here:
http://www.wholelattelove.com/tips.cfm?itemID=11
Has a lot of useful information that should fix your problem.
Posted on Apr 20, 2008
    Master:
    Sergeant:
  • 461 Answers
Try to reset the dispenser as below
1. turn it off
2. remove any power supply from the dispenser including remove out the plug from the main power supply
3. Leave it for 20 min
4. turn it on again....
My milk is no longer foaming! what gives?
Use fresh milk - skim or 1% actually works better than whole milk.
If that doesn't work, then your temperature is not getting high enough.
Jul 31, 2014 | Nespresso Aeroccino Automatic Milk Frother
Why do I have foam in my power steering reservoir
If it is up to the proper level and has been ran a bit and still has foam in it, the pump is sucking air. Replace pump.
Jun 21, 2014 | Cars & Trucks
DeLonghi Perfecta ESAM5500 when trying to make a cappucino it wont **** up the milk any ideas thanks
Had this exact problem a few times on a cleaned well maintained milk jug top with an ESAM5500M. Delonghi 'repaired' it by sending a new milk jug frothing top.
It's caused by milk fat deposits, the frother part on the milk jug may look clean but deep inside it's not. I clean mine with pipe cleaners, detergent and hot water and still it wouldn't froth.
The problem re-occurs for me every 6 months or so. You could buy the milk fat remover solution to clean it. Personally I just boil the whole milk jug frother in detergent and the again in descaling solution, that's fixed this problem twice now, although I think it will eventually corrode the 'o' rings on the frother, still cheaper than buying a new frother part each time though.
If it still doesn't work after that, the only other reason for this problem I found mention of was caused by a broken rubber seal where the milk jug fits to the machine. It's most likely to be milk fat deposits inside the frother though.
Jan 25, 2011 | DeLonghi Coffee Makers & Espresso Machines
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
How much is a Aeroccino Milk Frother
as of oct. 2nd 2010,amazon.com has them posted at $99.00
Oct 12, 2010 | Nespresso Aeroccino Automatic Milk Frother
It froth's milk beautifully but won't do soy milk.
We bought a Nespresso Milk Frother in 2010 for $100. The frother is the same one that comes with the Citiz machine but is a stand alone model. It froths soy milk very well. The less soy you put in it, the more froth you get but even if we fill it to the max line we still get a reasonable amount of foam. We use Silk brand soy milk. I have no idea if foaming is impacted by atmospheric pressure but it may be a factor to consider if you are using all the same factors as us but not getting great results. We live at a higher elevation Calgary, Canada in the foothills of the Rocky Mountains.
Sep 15, 2010 | Nespresso Aeroccino Automatic Milk Frother
Top stirrer
The small black stirrer doesn't froth the milk; wherease, the one that looks like a whisk froths the mil to make foam. So, if you want warm milk without the foam, use the black stir (it still makes a little froth) and if you want lots of foam, use the sliver one that looks like a whisk.
Sep 04, 2009 | Nespresso Aeroccino Automatic Milk Frother
Machine does not dispense milk properly
Hi
There is a pin in the cappucinator the needs to be turned slowly to create the venturi action to make it work. If you have lost the pin it won't work.
Mar 16, 2009 | Saeco Royal Digital Plus Coffee...
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Saeco Royal Professional Espresso Machine Logo
129 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
