Question about Poulan Pro Chain Saw 46cc 20"
Poulan pro chainsaw dies out when throttle is depressed, press throttle several times and it will rev up but holding full throttle the engine will bog down. have checked air filter dissasembled carb new gas / still same
  • haganj420 Jun 02, 2010
    sorry forgot to mention that the plug was changed also/ problem started beginning of this season. I seem to be getting good spark. thanks for all the help
Carb jets are probably rusted or clogged due to ethanol gas. I recomend replacing the carb. Will take adjustment once replaced, but a $25 dollar solution is cheaper than buying a new chainsaw!
Posted on Dec 24, 2010
    Problem Solver:
  • 16 Answers
Change your plug !
Posted on Jun 02, 2010
How do i adjust the carbarator on my poulan chain saw stalls out if running at full throttle when cutting
Ok, so there are 2 adjustment needles on the carburetor. A H and an L... If your saw is idling fine you won't have to worry about adjusting the L needle.
Your focus will be on the H... the high.
Firstly, if there is any plastic covers on the adjustment needles, remove them. Usually red and white in color... or just white. They serve no purpose(EPA regulations for California). Now adjustart in quarter turn increments.. turn the screw to the right until snug, now back it out 1 full turn. This is your starting point. While holding the trigger all the way in, turn the needle counter clockwise in quarter turn increments, use your ear to tell when you have peak performance.
If you can't hold it down cause it bogs out, just hold it in as much as you can while you turn the needle until you can fully depress the trigger all the way
Nov 01, 2015 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Poulan Pro Chainsaw, PP3516AVX
is the cap vent plugged?
Aug 18, 2012 | Poulan Garden
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
I have stihl chain saw it runes full throttle
After you let off of the throttle it dies instantly or just kind of quits slowly ?
It could be :
- 1 ) Your clutch is hanging up and not allowing the engine to idle while the chain is not moving.
- 2 ) You need to set the idle higher. You will need to remove the air cleaner, and find the small idle adjustment screw, and turn the screw clockwise, until it idles.
Please let me know.
Feb 08, 2010 | Poulan Pro Chain Saw 46cc 20"
Dies at full throttle.
Has it been standing for a while?
Few things to check.
1: Fuel filter in tank. Use a piece of bent wire to hook the filter through the filler hole and pull it out and swap it.They get gummed up with oil if they have been standing.
2: Fuel hose. Even the tiniest pinhole in the fuel line will cause exactly the problem you have.
3: Many chainsaws have another hose that goes from the crankcase to the carby, this is the "pulse line" and is just as critical as the fuel line.
4: Although one tuning jet is marked "H" for high speed, & one is marked "L" for low, at full revs they both deliver fuel, see if you can richen ( turn anti-clockwise ) the "L" jet a bit more and try that.
Please let me know and give me some more info, I have all confidence we can nail it.
Oct 15, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Difficulty starting Poulan 2250 . . .
hey pete
This is easy, prime bulb 5 to 7 times with choke lever full out. Pull string, once engine starts turn off choke and pull string again. ( throughout process do not pull trigger )Engine should start, let it idle 30 seconds, then finally pull trigger to rev up engine.
Jul 03, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan Pro Chain Saw 46cc 20" Logo
1,927 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
