Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Connect pool to filter 635
I have the 635 filter, and I am not sure what hose goes to which opening on pool to attach to.
    Guru:
  • 351 Answers
See if this picture helps you ..
Please Vote !!
Posted on Jun 02, 2010
I have a 635 pool pump how do i hook it up
One side is the suction side and one the pressure side, just run it to ID which. There is also and at each connection indicating in and out flow direction
May 01, 2012 | Intex Krystal Clear Model 635 Pool Filter...
Tip
How to fix the Model 635 pump issues
Take that piece of junk and toss it. There are simply no replacement parts available. Replace with a Pentair 3/4HP Dynamo and a 75 sq. ft. filter unit. You can use the existing Intex hoses with 1" couplers and pipe clamps. Buy a length of 1-1/2" flexible spa hose to connect from pump to filter. It'll cost about $400 all told for this setup (if you do the install yourself), but you'll recoup the cost in the 3-4 years you'd spend replacing the 635 annually.
on Jun 09, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Which hose do i connect to the filter and which to the pump
The hose that comes from the skimmer connects to the pump while the one that connects to the lower port of the pool connects to the filter. I hope this helps.
Aug 16, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Pump not putting water into pool from filter brand new just set it up
If your pool filter is new and you are having this problem, it sounds like you might have a loose connection or an air leak. Check your hose connections and make sure that your pump is primed.
Jul 18, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
It sucks fine but is not blowwing out very strong
sounds like air lock, but we will
try 2 things before turning back on
check hose where it goes into the pump sometimes hair builds up on the grate in the housing and catches other bigger debris
blast your cartridge filter with the hardest setting from your garden hose from top to bottom and flip then repeat
now put it all back together make sure to unscrew the bleeder cap at top of cartridge housing
open inlet on the suction side and wait for water to come out of the bleeder cap
now open the outlet side
now turn on filter pump and run for 20-30 seconds
now close bleeder
all air should be out now
Jul 16, 2009 | Intex Krystal Clear Model 635 Pool Filter...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
My vacuum for my 18' intex pool doesn't work right. Goes good for first minute and then suction is very low. Keep getting air in line. How do I solve this?
Make sure you have your tube completly filled with water. hold one end at the discharge while pump is running when full make sure both end of hose stay under water while connecting. I also leave the bleedee cap unscrewed just a bit to let air escape from the system HAVENT HAD A PROBLEM YET
Jun 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
281 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
