Question about Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. HDTV
How can I go about buying a X Sustain from CircuitCity??
    Scholar:
  • 137 Answers
Hello MDay02,
Here is how it works. When you finally decide that you want to purchase a board from us, We will send you a Pay pal invoice with the Total cost. We will also give you our contact number after payment is received, which will come in handy if you need assistant in installing the part. Assisting in installing is unlimited to that particular part. You can call us as many times as you want.
Best regards
circuitcity
Posted on Apr 09, 2008
6ya staff
SOURCE:
Will this Part No.: 6871QYH027A "Y Sustain Board" work in my Sony Plasma TV Model No.: PFM-42V1 ??
Check the sustain board fitted with the TV. You have to replace the same number. No substitution will work. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony Televison & Video
I have a Sony Plasma PFM-42 V1. When I turn it on
one of the electrolytic capacitor's are bad so one of the boards that control the TV are bad there is a good possibly its fixable but if you feel you don't want to I will buy the broken Tv from you so please email me at [email protected]
thank you
Jun 26, 2009 | Sony PFM-42V1 42 in. HD-Ready Plasma...
I got white vertical line running down a plasma display panel . they are close together that you cant even see on that side of the tv. on a closer inspection they are blue-green-red-blue-green-.... but...
A vertical line running down a plasma display can be caused by :
faulty buffer module.
Fauly sustain card.
Faulty plasma display.
Try unplugging power cable and see if this helps, if it does not , then you will need to call a technician.
In that case call the support number listed on your owner manual.
If warranty has expired, ask for a warranty extension, if available. this is cheaper than repair cost, and will cover the repair.
Jan 04, 2009 | Sony PFM-50C1 50 in. Plasma HDTV
My Sony Plasma Display
It sounds like you have a bad connection from either the X sustain or Y sustain boards to the panel itself. After the set warms up, the connection completes and the line goes away. First remember there are DANGEROUS HIGH VOLTAGES IN THE SET AND YOU CAN BE SERIOUSLY HARMED OR KILLED IF YOU TOUCH THE WRONG THING SO BE CAREFUL!. I would get a non conductive probe of plastic or wood and, with the set on and the back off, push on the ribbon cables which connect from the sustain boards to the panel. Once you determine which ribbon cable is the problem, disconnect the power, wait AT LEAST 30 MINUTES FOR THE VOLTAGES TO DRAIN OFF and then carefully resolder the ribbon cable connections at the sustain board in question. If the problem is at the panel end of the cable, I wouldn't recommend you try soldering there as it is very easy to damage the panel connections. You may try simply repositioning the ribbon cable to see if you can find a spot with a better connection. Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Sony PFM-42V1A/S High Altitude 42 in....
Sony PFM-42V1 bottom half of the screen is a blurry ghost image of top
The Sony Plasma designe not to repair at component level your problem I believe in YSUS PCB you can adjust a few variables resistors on this PCB make sure to mark on the spot before turn you can alway go back to original point, set your plasma on normal channel turn the variable resistor slowly and observe the picture any spot will effect the picture if you can not adjust you need to replace a new PCB
Let me know how you go
Oct 22, 2008 | Sony PFM-42V1 42 in. HD-Ready Plasma...
Sony plasma picture is blurry and makes a popping noise
Hello MDay02,
Your problem maybe your X board which is the same as PCB X sustain. Changing the fuse in this case may NOT solved your problem. If you are handy, you may be able to change the board yourself. We have most Sony X board in stock. If you purchase the board from us, we will walk you through the installation process for FREE over the phone.
Mar 17, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Pfm-42b1 service manual
I have Fix dozen of this set, and in all cases when they smoke and spark you have a bad Y sustain Board. This board is Normally not sold separate, but as part of the Panel. This would deem the set too expensive for repair. Part Number 9-885-048-48
Best regards
CircuitCity
Dec 05, 2007 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-50C1 Fuzzy Dim Display
Just want to let you know that the problem you are having is a bad X board. This board may not be available from Sony, because it is sold as part of the panel
Best regards
CircuitCity
Sep 28, 2007 | Sony PFM-50C1 50 in. Plasma HDTV
Sony PFM-50C1 50 in. Plasma HDTV Logo
117 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
