Question about Schwinn Exercise & Fitness
Error 1 code on a 815/825 Schwinn treadmill
Error 1 on a 815/825 Schwinn treadmill
5 Suggested Answers
joboo1
  • 257 Answers
SOURCE: How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 14, 2009
wigginss80
  • 11 Answers
SOURCE: treadmill shuts off in about 60 seconds.
try calling the techinal number tell them the problem and they should be able to help u
Posted on Jul 10, 2009
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
maxtreadmill
  • 832 Answers
SOURCE: asi image pro 2 treadmill error code 2
Loss signal or No Speed: 3 possible areas that can be causing the problem speed sensor , motor control Board ( MCB ) or the drive motor. Unplug unit remove motor shroud then plug in unit now on the MCB their should be L E D s lights should be on. One of the L E D s should speed on other P W M . Start your treadmill you see the PWM light flickering thus the upper console and cable connections are good now it will go back L S. Reset your treadmill then manually start pushing the running belt2_bing.gif now the speed light should be flickering if it does then the peed sensor is good if not flickering then replace sensor. If we have a good speed sensor then I would check the Drive Motor this done unplugging the unit the disconnect the two leads coming from the motor to MCB then by using a fully charge 18v drill battery connecting the leads to the motor should move it at approx; 1 mph then Your MCB is defective and need to be replaced. if no belt movement you for the most part will have worn brushes or open windings in the motor , I would open the brush compartment and inspect the brushes if they are less than 3/8" in length replace them this should the motor issue. Good Luck
Posted on May 15, 2010
How to fix Error Code E3 on Schwinn 6710P treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jul 30, 2015 | Schwinn Exercise & Fitness
How do I fix error 3 on schwinn treadmill
Feb 25, 2015 | Schwinn 6100/6300 Walking Belt
Safe key/lock out error
Mine has the same error, have you found a fix?
Mar 04, 2014 | Schwinn 840 Treadmill
Schwinn airdyne computer battery
it may need to be calibrated. Call schwinn or Treadmill Doctor at 800-750-4766 to walk you thru the calibration.
Jul 11, 2012 | Schwinn Airdyne Ad4 Upright Bike
E-1 message
1) Take the batteries, put new batteries , clean the contact batteries very well.
2)find the cord that move the plate magnet in the base wheel
3) Pull the magnet plate back to the wheell, now the error will be disappear.
God bless you
May 09, 2012 | Schwinn 250 Recumbent Bike
Error code 1 on schwinn elliptical 420
Dear Sir:
adjust the speed sensor see the diagram attached.
2) the main board can be faulty.
3) Run the software calibration.
5_3_2012_12_02_47_am.gif sincerely. God bless you
Apr 30, 2012 | Schwinn 420 Elliptical Trainer
Belt slipping on Schwinn Treadmill 5620P looking for local repair zip code 97405
http://www.youtube.com/watch?v=yX_0vRPdMfU&feature=related
See this video: and maybe you can do it.
after that you can continuing watching this other video.
http://www.youtube.com/watch?v=JC72OIKdluY&feature=related
if you insist to call some serviceman, contact:
www.unitedassemblers.com
you give your zip code and ready. sincerely.
E.CUADRA
MANAGUA, NICARAGUA C.A.
Nov 17, 2011 | Exercise & Fitness
Error code L5 on schwinn 820p
Landice L9 tredmill, L5 display on screen,belt runs slow and nothing else works to the touch.
May 13, 2010 | Schwinn 820 P Treadmill Silver Service...
Treadmill shuts off in about 60 seconds.
Jul 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
397 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
