Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Our 8640 john deere tractor loses power what could
Our 8640 john deere tractor loses power and takes a while to regain it, what could be some of the causes
5 Suggested Answers
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
How do i download a john deere 8640 repair manual?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
Why does my John Deere La145 lawn tractor lose power when climbing a small incline
Best Manuals
Mar 20, 2016 | John Deere Garden
This is a john deere tractor not lawn mower maybe have the wrong number it has frontend loader
Does it have good fresh dry fuel in it? Have you dumped the water bowl recently? Check that.
Aug 06, 2014 | John Deere 420,1020,2010,2020,2510,2520...
My john deere 316 loses power going up hills and when I have the mower pot on
Sounds very much like a fuel issue, i.e., starving for fuel. Check the fuel filter and replace.
Aug 04, 2014 | John Deere 300 / 316 Hydrostatic Tractors...
How to change transmission belt on x324 john deere lawn tractor
You could take it to the service dept at your John Deere dealership, if your service manual doesn't cover belt changes. Or Buy a service manual.
May 01, 2014 | John Deere Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Engine seems to run fine but when mower is engaged it loses power. It is a john deere 325.
Check to see if the mowing deck spins free or somewhat free with the engine off, It might be wrapped up with twine or something stopping from spinning, this will bog down the engine. Hope this helps.
May 29, 2011 | John Deere Garden
TRACTOR STARTS BUT LOSES POWER AND QUITS AFTER
Check to see if you have a fuel screen built into the top of the petcock (shut off valve) in the fuel tank. This may require you to drain the tank. Inspect the screen for being clogged. This is a very common problem. I hope this helps.
Jul 09, 2010 | John Deere 4010 Gas & Diesel Tractor...
JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Mar 21, 2009 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
191 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
