Question about Motorola Mobility RAZR V3
Phone in water
I dropped my new motorola 3Vxx in water, it was there no more than 10 seconds, The screen said critical error for a short time and then nothing, I have taken it all apart to dry out, it happened about 1 and a half hours ago, no luck yet. I have taken it apart again. Any hope?
Don't turn it on. Take battery off. Put in a bowl or bag of dry white rice, Leave for 3 days. If you are lucky it will be ready to charge and like new after the rice pulls the moisture out.
Posted on Apr 09, 2008
SOURCE:
MOTOROLA ADVENTURE V750 POWERS ON TO VERIZON LOGO FOR FEW SECONDS THEN GOES TO BLUE SCREEN....WAS RECENTLY DROPPED IN WATER AND SHOULD HAD PLENTY TIME TO DRY OUT AND HAVE EVEN TRIED PUTTIN IN RICE TO MAYBE...
Hi its a good indication that you still have water inside the phone.
to get rid of all the water in the circuts, you will need:
1 get a loner phone ( bcause the process i will show you here takes 10 days minimum to work).
you need a zip container with a lit, some desiccant bags 2 or 3 will do just fine.
salt can also be used as desiccant, but it should not touch the phone, use a papaer envelop or something
2 Blow dry the phone
3 put it in the container without the battery
4 put the desiccant bags inside
5 close it hermetically,
then go hide it in some dark spot for 10 days and be patient
Note that you might need a new battery.
Hope this helps
May 07, 2011 | Motorola Mobility Adventure v750 Cell...
Motorola 3vxx is muted. how to unmute?
I have just purchased an unlocked v3i razr. Mute will not unmute. Ideas?????? Speaker works fine.
Jan 22, 2010 | Motorola Mobility RAZR V3
My motorola 3vxx is pin1 blocked how can i unblock
Right whats happened is either the wrong code has been put in so many times.
You will need to call your network, to ask for assistance! Hope it helps!
Dec 23, 2009 | Motorola Mobility RAZR V3
My Motorola W385 from MetroPCS has a White Screen
It should be dry "after few years", Probably is time to get a new phone.
Mar 27, 2009 | Motorola Mobility W385 Cellular Phone
Razr 3vxx I want to disable the 3g function
If U just want use for normal call,Try change the normal Sim Card 64k,not 3G 128k Sim Card,then reset phone setting for MMS,GPRS.hope U can sofe the problem,reply me if can,[email protected],thk!
Nov 22, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Razor V3xx
The boot up is corrupted the phone needs to be reflash.
Jul 01, 2008 | Motorola Mobility RAZR V3
Problem with a RAZR V3
sounds like youve just had a short in your screen wiring. go back to where you got the phone and ask for an exchange
May 01, 2008 | Motorola Mobility RAZR V3
Sudden shut down
go to settings and go to initial setup, and click on master reset. the code is normaly 00000 or 12345
Aug 23, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
