Question about Sony FD Trinitron WEGA KD-36FS130 36" TV
Tuner doesn't work
All of a sudden, in the middle of a show, the TV channel changed from 3 to 6. At first, I couldn't change it to any other channel. It just scrolled 6, 66, and 666. Now I can get the tuner to rest on a station, but it changes back in a few seconds, unless I lock it in, which is the poor solution I am implementing now, with channel 3 (for the cable). Anyone have an idea what's going on? Thanks.
    Genius:
  • Sony Master
  • 1,689 Answers
I think this may be more of a fault with the uPC area on the main board than a tuner failure. It is possible to have both at fault, but this would be rare.
The numbers you see on the screen is from a pre-scaler circuit that drives a font generator in one of the IC's near to the uPC area. If you see the numbers changing this more from the uPC than from the tuner iteslf.
Jerry G.
Posted on Apr 19, 2008
Why does the channel up or down sometimes not work?
It sounds to me like you have a fault in the tuner circuit. I suggest you take it on for service.
Oct 23, 2014 | Magnavox MDR537H/F7 DVD Recorder 1TB Hard...
Westing House LD-3235 will not scan
It could be the tuner but you have a few options.
First is unplug the set and or a cable or sat box and wait a while. Plug back in to see if set/box will reboot.
Another option if you have or get a Box is get one with the audio/video output jacks on the back and connect it to the same type on the rear of your set-----Bypass the tuner and operate via that input changing channels on the box.
May 27, 2012 | Westinghouse LD-3235 32in LED 720p Flat...
Can't get "no signal" off
Hey cthaemar, it sounds like it may have been switched off the correct channel. If it is hooked up with a Coaxial cable it will be on channel 3 or 4, and if it is hooked up with an AV cable then it would be on one of the inputs.
If it's channel 3 or 4 try pressing the gray TV button on the remote and changing the channel. If that doesn't work you may need to use the TV's remote or the TV itself.
If it's on an input press the same gray TV button and then try pressing Input. With this you can also try the TV remote or the TV itself to change those if our remote doesn't change it.
Let me know if you have any other questions or concerns!
Tommy Faust
DISH Network
Jul 12, 2011 | DISH Network 322 DTV Receiver
I only get 3 channels--and none of them I want! Does this TV only work with a cable attached? Which doesn't make it portable!
If you live in the US and the TV doesn't have the newer ATSC (digital) tuner, you're lucky to get 3 channels! The only analog broadcasts left in the US are "low power" & "translator" stations. The old NTSC analog tuners in TV's from just a few years back have little to tune since broadcasters have been moved and changed from analog to digital as directed by the FCC in 2009.
I hope this helps & good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Axion Televison & Video
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
Snowy screen on tv
the 3 or for setting on the vcr is on the back( a switch)
or if the cable box has a channel 3 or 4 setting on the back of the box
but otherwise the tv may need some work on the tuner or need a new tuner
Dec 01, 2008 | Philips CCC130AT 13 in. TV/VCR Combo
Channels are not available on phillips tv
HI
CHANGE YOUR TV TUNER CHIP.
ALSO PUT REMOTE CONROL CHIP AND NEW REMOTE .
Mar 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
Channel gets stuck
I had the same problem on my TY tuner. The connection on the circuit board is bad. Has worked it's way loose. If your good with a soldiering iron you can fix it.
Jun 21, 2007 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
44 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
