Question about Industrial Home Security Burglar Alarm Yard Sign Light
Safe House Alarm system 49-470A goes off for no reason, even when it is not activated. Anyone know what the problem is and how to fix it?
2002 explorer anti-theft system activates while I'm in house (static). Might anyone have a probable cause ?
The "Proper" way is to use a scan tool with access to body body theft data. Usually alarm events set a code identifying which trigger set the alarm. "IE - B1234 Left Rear Door Alarm trigger Activation.
Since Most people dont HAVE an IDS or NGS or SnapOn...
You can try activating the alarm. all doors closed with windows down. wait 5 minutes. physically grab the top of each door panel thru the open window and shake the door hard like you were trying to pull it open. If its a marginal switch (usually is) the one thats borderline will trigger "open" with minor shaking and the good ones will show fully closed unless the door is in fact fully opened. If the shake test triggers the alarm on 1 door, then you know its either the pin switch (if it has one, not all do) or the door latch out of adjustment or defective.
Nov 12, 2015 | Cars & Trucks
Alarm at my house randomly goes off , it says bell tamp ,it is a pr5208 system , is there any trouble shooting points you could give me please
Do not know that system, but normally the bell is the outside horn or bell that sounds when the alarm is activated. Some systems have a tamper switch in the mounting box so if someone attempts to remove the horn while the system is set, the alarm sounds.
Feb 26, 2015 | Cars & Trucks
To whom it my consern my dodge neon sxt alarm is just going of for no reason and when i turn it on or it wont even turn on and it just goes of i tried the using the car hand alarm thing but it wont stop it...
check the battery in the fob it may be bad if the battery is try unhooking the cars battery for about one minute this should reset the system. if that dosent work then youll will have to chase down the open circuit thats causing the alarm to activate.
Sep 11, 2011 | 2003 Dodge Neon
1998 v6 regular mustang the original factory installed alarm system activates by itself 1-3 times a day for no reason.Once the car key is put into door and opened the alarm will go off. Also, the interior...
this happened to us when we got a new key and had it programmed with the car. anytime we locked the doors and opened them with the key instead of the remote, the alarm would set itself off. we took out the fuse for the alarm.
Jun 14, 2011 | 1998 Ford Mustang
I have a 2004 Chrysler Crossfire I cannot get the alarm system to turn off. Towing mode will not disable, every time a door is opened the alarm goes off and the alarm triggers again when I drive. I live...
I have the same problem on my 2004 crossfire :(
the alarm goes off out of the no where, even when i drive, the only way that i way able to turn it off was by taking one of the wires off the battery, then stops for a while but after a couple of day it happends again.
How can i reset the alarm system?
anyone knows?
Sep 18, 2010 | 2004 Chrysler Crossfire
2000 hyundai elantra alarm goes off where is the
There is NO kill switch on the 2000 Elantra... HOWEVER, there is a thing called the Key Fob (keyless remote entry system). There is, however, a system in place called the 'starter kill' circuit and it is activated when the burglar alarm goes off.... it's called the burglar alarm relay and it is activated to prevent the engine starter system from being used. There are three ways to get the engine started in such a circumstance... 1. use the key fob to 'disarm' the system... 2. put the key in the ignition and turn it to the 'RUN" position and wait until the alarm stops (horn stops beeping and the parking lights stop flashing), then the engine will start.... 3. pull the starter relay from the UnderHood junction box and bypass the starter circuit (key in ignition and in the 'RUN' position), jumper the starter solenoid circuit to energize the solenoid to start cranking the engine -- it should start then.
Oct 03, 2009 | 2000 Hyundai Elantra
Can't Change Code on MOD600 Alarm
Hi Michael, we have a MOD600 in our home also & need to reset the whole system - did you end up finding anything useful?
Apr 26, 2009 | Computers & Internet
ALARM RANDOMLY GOES OFF!!
the factory fit alarm is not voltage sensing .The best advice is to go to VW garage and get them to read the alarm causes,(they can check the last 4).this will give you a good idea where the fault lies.ie door lock mechanism,interior monitor etc..You cannot start looking for problem until you know alarm cause..
Feb 08, 2009 | 2000 Volkswagen Beetle
Industrial Home Security Burglar Alarm Yard Sign Light Logo
261 people viewed this question
Top Industrial Home Security Experts
Lawrence Oravetz
Are you an Industrial Home Security Expert? Answer questions, earn points and help others
