Question about Dishwashers
Whirlpool Quiet Partner 980
Will not run a cycle, only green clean light and red cancel lights go on. This has happened before but can't remember what combination of buttons to push to cancel and programming problem so it will cycle correctly.
Whirlpool Quiet partner II Type 280-2
  • 1 more comment
  • Anonymous Mar 15, 2014
    not spraying
  • Anonymous Mar 16, 2014
    Whirlpool Quiet Partner 1's clean button blinks continuously
  • Anonymous Mar 30, 2014
    Whirlpool Quiet Partner II
    President:
  • 2,651 Answers
Clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Posted on Apr 09, 2008
6ya staff
SOURCE:
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher takes 3 hours to wash, even on the light cycle
whirlpool Quiet partner 3 the clean light is flashing 7 times what does this mean
Mar 12, 2010 | Whirlpool Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Bad control board ,replace it.
May 26, 2008 | Dishwashers
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
1,338 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
