Question about Weiser Lock Powerbolt 1000 Lock
Need to change combination
How do I change the combination
  • 963 Answers
Here's a link to the Frequently Asked Questions page for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
The instructions for reprogramming the code can be found there. Good luck!!
Posted on Mar 05, 2011
How reset combination lock
1. Open the lock with the factory preset combination of 0005.
2. Find the tab on the end of the part of the locking mechanism that has the numbers.
Combination Reset Tab
3. Flip the tab up (with the combination set to the open combination). When you flip the tab up, you disengage the number dials from the tumblers, so that you can reset the combination without changing the position of the tumblers.
4. Change the combination to the desired combination.
5. Flip the tab back down. The dials are now re-engaged with the tumblers.
Aug 13, 2014 | OnGuard Doberman Series Lock 8030
Is it possible to reset a Manifoil MkIV combination lock without having to send it away to a specialist?
Hi, by reset, do you mean you have the combination but want to change it?
If so, then you need the special combination change key that came with the safe and the instruction manual (there are copies of the manual online if you don't have that)
If the door is open, but you don't have the combination, there is a technique for finding the combination.
amania_r@hotmail.com
Jan 06, 2011 | Office Equipment & Supplies
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jun 13, 2010 | Sentry Fireproof Safe
I can't find he manual to my bull safe. I need to know how to change the MASTER combination. There are 2 combinations that currently work on the safe. One combination is for my employees (I am able to...
Hi there Marchel,
I was the one you spoke to over the chat a while ago. As I already gave you the instructions and the manual, still you rated me as not helpful and rejected the solution I provided.
Was it just a mistake? I hope you still accept my solution at it reflects bad on my performance.
Please dont hesitate to ask if you have questions.
Thank you :)
Sep 10, 2009 | Office Equipment & Supplies
Need instructions on changing combo
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Change the combination to a Sentry 2260 safe. I have original combination and all I just need to change the combination.
Safe and vault techs would advise you
1. Press the Program key.
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Jun 08, 2009 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
SENTRY SAFE
Locksmiths agree the factory code is burnt into memory and can not be erased. When you buy a sentry safe you have to set a user code to give out as that code can be changed. program instructions
Jul 03, 2008 | Sentry Fireproof Safe
Weiser Lock Powerbolt 1000 Lock Logo
386 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
