Question about Homelite Consumer Products Backpack Blower/Vac, Carb
Homelite backpack blower bogs down with load - Homelite Consumer Products Backpack Blower/Vac, Carb
I can not start blower ppb430vs old 2 years
Posted on Jun 02, 2010
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
I need a gastank for my homelite-backpack leafblower, model#uto8580a.It leakes around the screw that holds it own. This is the second time i've had to replace it. There must be a defect in these.
There is a recall for leaking fuel tanks on your unit.
The Homelite #UT08580/UT08580A Backpack blower service recall and all related questions and issues, are being handled through the Homelite customer service phone staff at 1-800-242-4672, for records purposes.
Aug 22, 2011 | Homelite Consumer Products Backpack...
Bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Jan 06, 2010 | Homelite Consumer Products Backpack...
Just started bogging down when I try to give it gas.
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
5) carburetor gaskets/diaphragms
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 09, 2009 | Homelite Consumer Products Backpack...
Blower will not achieve maximum rpms and bogs down when accelerated
most new homelites etc have the high speed screw too lean because of epa standards---you usually need a special tool either a splined or pac man screwdriver to open the adjustment screw another 1/4 to 1/2 turn to get the right rpm's
Nov 07, 2009 | Homelite Consumer Products Backpack...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Engine cut out
On the bottom of the carb. there is a plate held on by one screw, take that plate off and very lightly clean the screen on the carb with a bread tie wire, this worked very well for me. Mine runs great now:)
Nov 08, 2008 | Homelite Consumer Products Backpack...
Homelite Consumer Products Backpack Blower/Vac, Carb Logo
541 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
