Question about Sharp AF-S120FX Air Conditioner
How would I clean an air conditioner - af-505m6b...i cleaned off the vent that slides out of the right but the front is still a bit dusty and it's a pain to try w/ a cloth (like a clorox disinfecting wipe) its just hard to get all of it.
5 Suggested Answers
Healeyman
  • 1198 Answers
SOURCE: Room Air condotioner Sharp AF-S120FX-A noise from middle of fan
You can get a zoom spout oiler at your hardware store. Slide the ac out of its housing until you can see the fan motor clearly. Use a flashlight to see the shaft. Put oil right where the shaft goes into the motor, both places if you can see them. While there, check the ac for sludge or anything else you can **** up with a shop vac.
Posted on Apr 29, 2009
  • 18 Answers
SOURCE: I have a Sharp window air conditioner, and when it
the part of the ac inside the room should be slightly higher than outside
Posted on Jul 28, 2009
mcdevito75
  • 1970 Answers
SOURCE: how to clean filters in AF-R509X sharp air
mcdevito75 here, Filter located just under the front cover where the controls are.
Posted on Jun 26, 2010
  • 11800 Answers
SOURCE: sharp AF-M808X air conditioner. suddenly
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Posted on Jul 22, 2011
How do I take out a a.c filter to clean without damaging it
Good Morning Maria - Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well.
May 29, 2013 | Frigidaire FAC126P1 wall/window Air...
Clean Filter
Good Afternoon Kate - Thank you for your question! Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well. Hope this helps!
May 24, 2013 | Frigidaire FAA065M7A Air Conditioner
I canit open the door to change the filter
Hi -
Hello - Some air conditioner filters are removed by sliding out from the right-hand side. Others, you need to push the vent handle to the Vent Closed position and open the front panel. Grasp the filter by center and pull up and out the filter can be wash using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing. Keep in mind that instead of washing you may vacuum the filter clean as well.
Oct 14, 2012 | Frigidaire FAX052P7 Compact Room Air...
I have a Portable Windchaser Air Conditioner and the back filter looks very dusty. Should I replace or clean the filter? There doesn't seem to be a way to remove it without disassembling it. Thanks...
these filters can usually be removed and cleaned by carefully sliding it upwards. Some units they just unclip, pop off with a sligh force. However removing the filter will only expose the evaporator, it is MUCH recommended to remove the entire back cover of the unit to gain access to the condenser and clean both of the radiators.
Aug 20, 2011 | Windchaser PAC9 Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Water leaking on carpet. drain plugged?
Make sure it is pitched right and yes the \drain could be blocked. There should be screws on the side and the hold unit will slide out of the caseing then clean it with a hose let dry for and hour or so should be good.
Aug 28, 2010 | Sharp AF-M1909Y Air Conditioner
Where is the filter
It's behind the front grill underneath the vent. Some window A/C you can slide the filter out from the side or the bottom. Some you have to pull the whole front cover out. Some is part of the front grill and is not removable, and can be cleaned out instead of replacing.
Jul 09, 2010 | Goldstar R5050 Air Conditioner
Insufficient cooling with window air conditioner
The air conditioner should be big enough. It is hard to say whether or not the 46-47 degrees is right as you did not give a room temperature. The first thing to do before installing a used unit is to thoroughly clean it. Use your garden house to rinse both the evaporator and condenser coils. Also ensure the filter is clean. If the unit is still not cooling properly it likely needs a shot of refrigerant. Beyond cleaning the unit I would not recommend other do it yourself fixes.
Jun 27, 2010 | Heating & Cooling
How to clean filters in AF-R509X sharp air conditioner? where s the filter located?
Jun 26, 2010 | Sharp AF-R509X Air Conditioner
Filter cleaning
The filters are located on the isnside unit in the front. Sometimes there may be a screw or two to undo, but usually not. The front vented looking part will lift up, or you can pull the filter out from the top of it. It depends on the model, but that is the two ways to get to them...once out, a mild soap or rinse with plain water will clean them. If they have pet hair or very thick build up, you may use a soft brush on them. Let dry and slide filters back in. Hope this helps.
Jul 31, 2008 | Sanyo 12KS51 11800 BTU Cooling Only Mini...
Sharp AF-S120FX Air Conditioner Logo
107 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
