Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyostove laser 73 displays ee 10. Toyo is brand new, no obstructions in flue, fuel tank is a good height, only pressed red button once for a second, blower fan works.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
ONCCON,
EE10 is not good. This means you had a flame in the pot when there should not have been one. The red button is to be used very carefully. One time for one second. I think you have pushed the button too much and got a fair amount of fuel into the burner. Without pushing the red button try the stove again. If you burn out the fuel in the burner the stove will operate normally. If the code continues I would look at the hook up for the air and exhaust to be sure they are correct. If they are backward it can cause an EE10.
Keep us posted,
Tom
Posted on Jun 02, 2010
I let my tank empty before refueling and now my toyo laser 56 has a ee 2 error on it how can i fix this?
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Jan 03, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
You may have an air bubble in the fuel line or the filter (if you have one at the fuel barrel) may be clogged. The filter has a vent screw on top and you may need to vent the filter to get the fuel flowing. There is also a strainer in the fuel sump that may have gotten clogged.
Another thing is to push the red float reset button on the right side of the heater. If the float is latched up you will feel a little resistance and hear the float drop. Only press the reset button momentarily. It is not a primer button.
You can get a bowl and some rags to set under the line where it connects to the back of the heater and then loosen the line to make sure you are getting kerosene to the heater.
The fuel pump makes a loud ticking or thumping sound if it isn't getting any fuel.
Let me know if this helps or you need more advice.
Nov 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
My toyo 73 has started making a loud vibrating noise during startup but gets quiet after running a little while...the fan is not on during start up....
The fan blowing air to the room might not be on but the flue fan would be. I reckon this is where the noise might be from. Fan impellors get coated with dust and this throws the balance out (similar to a car wheel if you loose one of the balance weights). Highly recommend getting it serviced by a good technician. Always good practice every year or so and might fix the problem.
Sep 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo73 displays ee-2
Tootone,
Try this lick to REE. They are Toyotomi supplier on the west coast.
http://www.rural-energy.com/publications/catalog/document/334
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Mar 02, 2009 | Rinnai Toyostove Direct Vent Heater:...
Does not extinguish
If your fuel was yellow it was #2 home heating oil. Toyotomi Laser heater run well on #1. Since yours in giving you a EE10 message you are going to have to open the burner and clean it, the blower and the heat exchanger. The air holes are blocked on the burner and it takes too long to burn the fuel up, EE10.
This is a dirty job but not that difficult. Try toyotomiusa.com/ and use their dealer locator. You should find a dealer in South Dakota that will be able to get you some gaskets you might need.
Good luck,
Tom Hawkins
hawkins111@gci.net
Jan 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Laser 73, starts, fires then goes out, flashes EE02
here is the problems associated with code EE02.
problem cause solution
no ignition: out of fuel check fuel gauge or tank, refuel
fuel tank valve closed open valve turning clockwise
air pocket in fuel line push reset button on the fuel sump, located right inside .
once
clogged flue pipe clean flue pipe
clogged fuel strainer clean fuel strainer
ignitor,circuit board, consult dealer
flame sensor, or fuel
pump malfunction.
it sounds like it may be a clogged strainer located in fuel sump or a bad circuit board hope this helps
Jan 22, 2009 | Rinnai Toyostove Direct Vent Heater:...
I have a monitor 2200 that is reading ee 13. what does that mean?
EE13 on a Monitor is one thing. The same code on a Toyostove is completely different. A Monitor EE13 means there was no flame at ignition. On a toyostove EE13 is the burner thermistor.
On the Monitor I would check my fuel tank. On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Tom Hawkins
Bethel, Alaska
Dec 26, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo stove laser 30
EE22 means that your Toyo failed to ignite 3 times in a row. You need to unplug it for 30 minutes to reset the circuit board. Then plug it back in, push the red reset button on the right hand side in the little hole towards the back and push the Power button. Your Toyo should ignite after that barring some other problem caused by running out of fuel.
I am assuming that you ran out of fuel which caused the EE2 error code originally. Sometimes, when you run out of fuel you can get water, ice, debris in the fuel line causing an obstruction or limited fuel flow. You may also get an air lock. You may need to crack the fuel line at the back of the Toyo where there is 3/4 nut and bleed the line. If you see no fuel or a small quantity of fuel then you will need to thaw and/or purge the fuel line in order to get fuel to your Toyo's fuel pump.There is also a screen in the sump which can get plugged with rust, debris from the bottom of the fuel tank so you may need to clean the screen in order to get fuel to the pump.
Nov 12, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 73 EE2
The firing sequence for a L73 is blink, blink, blink, on the green burner light, then it clicks up to the medium, amber or yellow light...that's when the pump kicks on. If you hear click, click, click, or thump, thump, thump, that means the pump is starving for fuel. The problem is from the carburaot/sump back to the fuel tank. You may have icing in your line or a line restriction, no fuel, plugged fuel filter or plugged sump screen. You can thaw your fuel line, until you have a free flow of fuel and then push the red restart button on top of the sump. Try to restart your Toyo.
If you follow the firing sequence and hear no click, click, click or thump , thump, thump and your Toyo goes off on EE2 then you can have a dirty flame sensor...the whilte wire running to a U shaped part that is the ground for the entire unit. You can take ythe ytwo phillips screws out, turn the part to the side and wiggle it out. Clean it qith a green scrubby or sandpaper and put it back in. Be sure it points stright down. Then take out the igniter which are the red wires. Put a long screw driver in there and rattle it around real good. You are trying to shake any carbon cxhains off the burner ring that can be "shorting" the flame sensor. You can also removee the 1/2 inch flare nut from the fuel nozzle...brass yellow colored metal part, and put a paper clip or wire down that about 3 inches. That will clear any blockage in front or inside it. Put everything back together, hit the red reset button on the sump and re-fire your Toyo. You might get it going in this manner. If not, you may need a tuneup because your Toyo is too sooted up to run correctly. Try these things and post back!
Nov 10, 2008 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
263 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
