I have model # GWL 11. serial #uun636512. When I turn the power on to the machine, the second light in the status bar doesn't light up. I tried to reset by running through the other cycles until the end. The light still remains unlit when powering on. PLEASE HELP! Thank you.
  • luisa_sgro Jun 02, 2010
    is that light the regular button? if the machine still works on the other cycles then it is your display board that is faulty. when you say status bar is that the wash progress lights or the wash cycle lights with descriptions like regular or wool etc? please reply for further help
  • wweems1 Jun 02, 2010
    There is a service summary with error codes under the control panel in a zip lock bag.
  • 159 Answers
Hi there,If this isn't affecting the wash cycles in any way then you don't really have to worry about it to much.it's just a dead LED (light emmitting diode)just a dead light.or if you are really worried about it you can change the whole display board & pay $$$.Or if your really confident to repair it yourself you can buy an LED & break out the soldering iron,i personally wouldn't worry about it.The only time that light would be needed would be if the machine ever broke down & was displaying a fault code useing those lights across the top.Hope this was good advice.
Posted on Jun 03, 2010
Fisher and paykel model gwl 11 drains but wont high spin
they have a speed sensor at the bottom on side of motor if faulty it wont let motor spin up. sometimes it can be a computer panel issue .
if machine does the check lights and beep ok likely it is sensor
Feb 25, 2017 | Fisher and Paykel Washing Machines
Gwl 11 wont rinse or spin
(00000101) Phase 1 - Communications Fault
The Display Module has had difficulty communicating with the Motor Controller.
Primary Source: Display Module.
Action: Turn off at the wall and on again after 5 seconds and try again.
1. Undo 2 screws at the back
Check connections of the 12 way harness for bad contacts,
corrosion etc.
2. Check for moisture in the console area. Dry out if necessary
2. If still faulty, replace the Display Module
3. If still faulty, replace the Motor Controller. If the new Motor
Controller corrects the fault, then refit the original Motor Controller.
Oct 11, 2014 | Fisher and Paykel Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washing Machine Model GWL 11
The power supply needs three resistors removed,R129,R130,R131.
and one 1megOhm put in it's place.
Feb 25, 2012 | Fisher and Paykel Washing Machines
Suddenly the spin cycle won't work. The motor makes a funny noise. The drum just remaiins still. Model GWL 11. The lights are on and there is no alarm.
Hi just read your posting.Now, does the machine drain?What lights are on?Does the machine fill with water and agitate?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
