Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Water dripping inside refrigerator compartment
Thought problem was that unit was stuck in defrost mode,
now believe drain is clogged.
Where is drain ?
How can I unclog myself ?
    Novelist:
  • 77 Answers
The drain is behind the freezer wall. Unplug the refrigerator first. Then you need to empty out all the food in the freezer. The screws holding the back wall in are generally 1/4 inch nut driver and phillips head screws. Take out the screws and the ice maker if you need to.
The drain is in the back on the bottom, and probably under a bunch of frozen ice. Just be careful not to damage the freezer, but chip away with a flat blade screwdriver, or just use the hairdryer on it all. You will need to soak up the water with a tower, there will probably be a lot. Next, you need to thaw out the drain, this can be somewhat difficult. Simply blowing hot air doesn't do much good, because it's a small hole. I take some 1/4 inch plastic water line and **** the water out. Then I pour HOT water (from the microwave) down the drain. I let it sit a bit and then I **** it out and reapply.
This process should get it clean. Also, once it's free, I take the 1/4 inch plastic water line and stuff it down the vent a LONG way and make sure any obstruction is removed.
Posted on Jun 02, 2010
Water goes into the bottom of the refrigerator so much so that it leaks out onto the floor. The freezer and refrigerator seem to be working well, however.
This unit appears to drip defrost cycle water down the inside the back wall of the fresh food compartment to the fresh food compartment drain. There is a tube connected to that drain that is item 84 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=114825&diagram_id=28705718#d28705718
You need to make sure that the compartment drain and the tube to the drip pan is free of obstructions. It is not uncommon after a long period for the compartment drain to clog. Also underneath the unit were the tube terminates in the drip pan the very end of the tube can sit in some pretty foul muck and clog just from drying out with lint and gunk on the end of the tube between defrost cycles. I often poke spot / zip ties in them initially to clear obstructions because they are so dirty.
Please feel free to respond with any more commets at any time if cleaning the drain tube and catch basin do not resolve the issue.
Thanks for choosing FixYa,
Kelly
Aug 18, 2011 | Frigidaire FRT18S6AW Top Freezer...
Maytag MZZD2766GE side by side refrigerator: Water collects and freezes on the floor inside the freezer. Then apparently some of the ice defrosts as I get water on the kitchen floor under the...
Hi and welcome to FixYa, I am Kelly.
This is caused by a clogged evaporator drain that is item 5 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966
It can be clogged either in the funnel area or at the end of the tube underneath the refrigerator.
Item 5 catches water from item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966&diagram_id=28494316#d28494316
Your evaporator drain is clogged. (how to clear it)
  • Unplug the unit remove the freezer contents and do a manual defrost by directing an external fan at the freezer compartment for just over 2 hours. (Makes a water mess so be prepaired) This is a must do!
  • Remove the rear fiber-board compressor and condensor coil cover and locate the compartment drain tube in the drip pan. Make sure the end of the tube is NOT blocked. Clean as necessary.
  • After the 2 hour period... use vacuum forced air OUT pressure on the end of the drain hose in the drip pan. Have a 2nd person listen for airflow in the freezer compartment. This will float out any debris from the compartment drain funnel.
  • Clean the condensor coils and fan while the unit is unplugged but do NOT use anything sharp.
If you can not get air-flow up through the compartment drain funnel underneath the evaporator coils you will have to remove the access panel and remove the debris from the drain funnel.
Return the unit to normal service after cleaning. Watch for more ice build up after a week. No ice blocks after a week... no worries. Ice under the ice-maker... replace the inlet water valve due to it bypassing water when in the OFF mode.
Kelly
Mar 01, 2011 | Maytag MZD2766GES Side by Side...
Water dripped on bottom of fridge
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
Think this will solve the problem....
Jul 28, 2010 | Kenmore 57029 Side by Side Refrigerator
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 | Freezers
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 07, 2009 | Refrigerators
Water dripping in refrigerator compartment
This is an indication that the defrost drain is clogged or blocked. Below is a link that will help you resolve the problem. Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Refrigerators
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Water dripping from freezer when defrost kicks on.
You probably have a plugged drain in the freezer compartment. Open that up and check it. Hope this helps!
Feb 16, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
296 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
