Question about Great States 20" Scotts Classic Push Reel Mower
Rear wheel on a scotts 20" reel mower
The rear wheel on a scotts 20" classic reel mower is broken. (Don't ask) Can a replacement be obtained??
jgr4
  • 9 Answers
SOURCE: Scotts Classic 20" drive gear problem
In addition to lubrication problems, the plastic pinion gears can wear down or deform. This can cuase them not to engage, even if well-lubed.
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Posted on Jul 14, 2009
jgr4
  • 9 Answers
SOURCE: Wheels won't engage the reel of the mower.
Pop the cover off the center of the wheel with a small flat-blade screwdriver.
Pry the lock ring off the axle, again with the flat-blade screwdriver.
Lift the wheel off.
The small gear (pinion) lifts off of its axle. You may just need to lubricate the pinion gear and the little bar of metal that it engages. If the pinion is damaged, buy new ones; they're pretty cheap.
When reassembling, the lockring is easily clicked back on with a pair of pliers.
jgr4
  • 9 Answers
SOURCE: Scotts reel mower gear problem
wayneard
  • 1901 Answers
SOURCE: I need to find replacement parts for my Scotts 18
I believe this company can help you with that.
https://www.reelin.com/CustomerDefault.aspx
There is a toll free number on the web site.
Hope this helps.
Thanks for using Fixya.
Posted on Aug 20, 2009
SOURCE: reel mower isn't engaging -- blades aren't rotating and cutting
My Scotts Elite has the same problem. I disassembled the wheel and there is a plastic sprocket that is worn down on the inside where it catches to engage the blades. I have been searching for a while and can't find a replacement part on the internet. Unfortunately i think the lawnmower is done unless you can find the replacement part. Looks like part number is PA66. You would need two, one for each wheel.
Posted on May 23, 2010
Replacing the pinion gears in each wheel. Which way do the ratchet pawls go?
the pawls are positioned so that when the wheels rotate in a forward direction they lock up the pinion and drive the cutter blades ,
they release when the mower is pulled backwards
as for grease , if it had none then none is what is used
If it had grease then a water resistant bearing grease would be prefered
May 28, 2016 | Scotts 20" Classic Reel Mower
My handle broke off. Where can I get a new
I would consider asking around at repair shops to find another handle for a sensible price. Or...someone at one of those shops might be able to weld the handle back together?
Jun 25, 2010 | Great States 20" Scotts Classic Push Reel...
The handle snapped off my mower. Everything else works fine, but It's useless without a good way of pushing it. How do I get a new handle?
Hi and welcome to FixYa. I am Kelly. The handle is in 2 parts. The lower handle and the handle extension. You can order them here:
https://www.reelin.com/ItemGroupItems.aspx?ItemGroupID=58
31108-2 - LOWER HANDLE 20" RH - QTY 1 EA. $6.30 button_in_cart_new.gif 31108-3 - LOWER HANDLE 20" LH-BLKTX - QTY 1 EA. $6.30 button_in_cart_new.gif
31098-3 - CENTER HANDLE SEC-BLKTX - QTY 1 EA. $7.05
button_in_cart_new.gif 31099-3 - TOP HANDLE SECTION-BLKTX - QTY 1 EA. $6.15
Hopefully you know which part of the handle that you need.
You can contact them here:
American Lawn Mower Co.
P. O. Box 369
Shelbyville, IN
46176
Consumer Hotline: 1-800-633-1501
Email: Sales@reelin.com
Thanks for using FixYa.
Kelly
May 30, 2010 | Great States 20" Scotts Classic Push Reel...
Scott bonner reel mower. Throttle cable.
look up mower throttle cables on google or type in throttle assembly it should show you how it fits on they are all very similar
Jan 13, 2010 | Garden
I need to find replacement parts for my Scotts 18" Deluxe Reel Mower. Where can I find some?
Hope this helps.
Aug 20, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Lift the wheel off.
Jun 17, 2009 | Great States 20" Scotts Classic Push Reel...
Jun 09, 2009 | Great States 20" Scotts Classic Push Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Jun 05, 2009 | Great States 20" Scotts Classic Push Reel...
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Great States 20" Scotts Classic Push Reel Mower Logo
44 people viewed this question
Top Great States Garden Experts
Dennis Key
Dennis Key
Marco De La Fuente...
Salvagedrover
Are you a Great States Garden Expert? Answer questions, earn points and help others
