Question about GE Advantium 120 Convection/Microwave Oven
Our turn table doesn't turn anymore . . .something underneath seems to be broken. Thank you!
  • japanhumps Jun 02, 2010
    OK, we'll try it! Thank you!
  • 5,911 Answers
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price range will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you need. You may also consider replacing the turntable shaft if it shows signs of wear.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Posted on Jun 02, 2010
Testimonial: "We do have the over the range model, GE Advantium #SCA2001. The shaft is very loose and wobbly, but does not come all the way out. I don't think it is the motor, because when I pull the tray out, and turn on the microwave, the shaft turns by itself. Any ideas?"
  • Jeff Rockwell
    Jeff Rockwell Jun 02, 2010
    It could still be the motor. If the turntable will not turn with the glass tray installed, but WILL turn without it, the motor is probably worn out. As these small motors age, they can become weak to the point where they do not work under any kind of load. This is a common symptom.
Microwave turn table does not work
Check for a broken rubber drive belt underneath
Apr 11, 2015 | Microwave Ovens
Turntable on hotpoint RVM1435 microwave does not work how do I make it turn?
usually a sign that the belt has broken underneath replace or live without turn table
Dec 25, 2014 | Hotpoint Microwave Ovens
Turn table doesn't working on my microwave anymore
The turntable is driven by a small electric motor mounted underneath your microwave oven. The motor may have failed. The motor is accessible from underneath the unit and usually a cover plate has to be removed to gain access
Oct 06, 2013 | Microwave Ovens
Why microwave does not heat anymore
Well, we are looking at a bad magnetron, cracked high voltage diode, or a shorted high volage capacitor. I would suggest replacing the microwave oven because the expence involved to have it serviced.
Mar 29, 2012 | GE Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
TURN TABLE DOES NOT OPERATE. WHIRLPOOL MICROWAVE Sep 06 Ser #RT 37 13345
Hello!
There is a small motor inside the bottom of the microwave that turns the table. Check the base and see if that is not broken. If that is ok, it is most likely that the motor for that is shot. It is easy to fix but may not be worth the hassle.
You need to remove the cabinet (while unplugged, naturally) and take the bottom apart to replace this. There may also be a small cover underneath the machine which accesses this part, saving trouble, so check there first. Unscrew the small motor and take to a parts dealer in your area for pricing of replacement
Hope this helps, Please rate and comment, Thank You Joe
Sep 07, 2011 | Whirlpool Microwave Ovens
The glass turn table wont spin??
Hi, Your problem lies with one or both areas. If you remove the glass turn table, you'll see a plastic grooved driver that goes thru the floor. See if you can lift up and remove it. Does it look broken? If not, there is a drive motor underneath that drives this plastic piece which turns the turntable. You'll need the model number to take to your local parts house for replacements. Hope this helps.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Everything works except turntable and does not heat up
you have a bad turn table motor or broken coupling.remove the dish does it turn?if yes motor is stripped ,make sure plastic coupling does not pull out .You can access the motor from underneath unit 6-8 screws and the panel swings down for easy access (common problem)Please rate my answer :)
Dec 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
146 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
