Question about Fisher and Paykel WA37T26G Top Load Washer
Will not deain or spin - Fisher and Paykel WA37T26G Top Load Washer
  • Fisher and P... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinewill not deain or spin - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Not spinning and makes loud noise
Motor coupling failure is the most likely suspect. Easy and cheap to fix. It is a simple rubber "shock absorber" that links the motor to the transmission. Search for washer online and most likely you'll find the part and the easy repair instructions.
Jan 05, 2015 | Roper Washing Machines
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Can door ajar light deain the barrwey down
Yes if left on over night in a weak battery With all the cold weather it could be too weak to handle the drain and need to be replaced Check with your local auto parts store they can scan for problems and also test your battery for free
Feb 02, 2014 | 1997 Ford Expedition
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
Kawasaki ZZR 250. Engine hydrauliced after fuel
sounds like you blew a set of piston rings. instead of building compression in the cylinder its pressurizing your crank case forceing the oil out the breather into your air box
Dec 18, 2009 | 1992 kawasaki ZZR 250
Wet floor on driver side only; Prevelant after heavy rain
Have your ac evaporator deain cleaned out or checked. Without this working the ac water will collect there.
Jun 19, 2009 | 1999 Toyota Corolla
WASHER WILL NOT SPIN OR DEAIN
I've had that problem twice in the last decade. In both cases it was the water inlet valve. That's the gizmo that both water hoses are connected to on the back. You'll need an ohm meter to see if the valve is good; if it's bad, it's really simple to replace it, and costs around $30. (Of course you'll need the make/model of youjr washer to buy the part.)
Scoop the water out of the tub and move the washer out so you have access to the back. Remove both hoses from the washer and unscrew the back panel. Disconnect the leads from both terminals of the valve solenoids. Set your OHM meter on RX1 and probe both leads on a solenoid (do this for both solenoids). The reading will be between 100 - 1,000 for good solenoids.
I've found the absolute best book for repairs is the New Fix-It-Yourself Manual by Reader's Digest. Excellent drawings, troubleshooting, and instructions. I bought mine about 1996, and this year online, I bought 3 used books in excellent condition for my kids.
Feb 06, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Fisher and Paykel WA37T26G Top Load Washer Logo
245 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
