Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Led stand by light blinking
Led light blinking 9/10 times stops and then starts again
No picture
Could it be the bulb? TV is 5 years old
  • mkaroul Jun 01, 2010
    Model KP 46WT520
  • Sony Master
  • 5,138 Answers
No power supply proble Google to Encompass Parts Distribution and type in your model number.
Posted on Jun 01, 2010
  • ladywinn
    ladywinn Jun 02, 2010
    Good chance it is the Lamp Call Mats for Lamp $99.00
    If the Lamp has never been replace then replace it first.
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
I have a 4 year old Sony KDF-E42A10 television - the power/standby light blinks red 5 times, pauses, blinks red 5 times again, etc. I have replaced the lamp previously when the light was blinking red 3...
5 blinks means there is a problem with the video board. It could be as simple as unplugging everything, includding power. Wait 3 minutes then plug power only back in. Or it may be a damaged component that requires replacing.
Hope this helps
TV_Doctors
Jan 05, 2011 | Sony Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a Sony ' Wega " about 6 years old 36 HD.. I turned it on and the stand by light blinks NO PICTURE.. OR SOUND AT FIRST IT MADE SOUND AND I THOUGHT PICTURE WAS GOING TO GO ON IT SHUT OFF...CAN YOU...
Please intimate exact model of Sony TV and how many times LED blinks as there would be 3 second pause between blinks so count blinks and let me know. This LED blink is an error code that will tell me problem section in TV.
Thanks.
Sep 07, 2009 | Sony Televison & Video
TV INOP
Sounds like you need to replacew the lamp.
Jul 08, 2009 | Televison & Video
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
TV does not turn on...stand by light blinks 9 times and then stops and starts again. TV is only 4 years old
Without knowing the model or type of set I'm assuning it is a dlp . if so change the lamp.
Apr 23, 2009 | Televison & Video
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
407 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
