Question about Drills
I have a Rockwell 15.017 drill press. it has developed a large runout at the chuck. How do I get the Jacobs chuck off the bottom of the post? Where can I get a parts list for this drill press?
  • brigittedave Jun 02, 2010
    the pdf address didn't cononect for me--the question still remsains "how to remove the Jacobs chuch".
    I finally got the pdf file to display--thanks--it is a great help. ---The instructions to remove the chuch look complete and should get the job done. Thanks--and thanks also for the Rockwell address.
  • 3,600 Answers
I see this has been here for a day so I am going to give you the phone number to get to Rockwell parts where you can order the part you need and the instructions on how to replace the Rockwell Drill Press chuck. here is the web page with their 800 number. I hope this helps and apologize for it taking s long to get a resolution to your question thanks for using fix-ya.
http://www.rockwelltools.com/service_parts.htm
Posted on Jun 02, 2010
  • 2,100 Answers
Well after searching for almost 30 mins, I found a site with diagrams of the spindle and quill. It looks to be a newer model, I think your 15.017 is older. anyway, check it out, I hope it will help. The other pages all say to call Delta tools and they will help you, I have the number out in my shop some where. Let me know if you need it. I have an old atlas drill press and I tried to get my spindle out, guess what, I never got it out, I left it in there. I welded the worn spots on the quill and then ground out the slots with a dremel, It works, but it looks like something congress would do.
http://www.owwm.com/pubs/1141/903.pdf
  • Ned  White
    Ned White Jun 02, 2010
    I thought you could get an idea from the print, but if you can't see it, it does no good. I know that it comes out from the bottom. The chuck should have a screw inside it and it also gets knocked out with a brass hammer or brass driver, The instructions tell you to swing the table out of the way so you can get the quill out, Take off the pulley and the feed handle, you should see some set screws in there. There is one at the top of the quill, along with a bronze bearing and washer, top and bottom, at the top you will find a sleave and bearing, they come off, and by now, the quill should drop out or tap out, along with the spindle. I have addresses of parts places for this, where do you live? I will send you the address. I don't know why the PDF thing won't open for you. Has all kinds of good stuff in there. Don't forget, you can call delta, they will help. Oh and if you just need the chuck off, look for the screw inside and if not, lock up the spindle some how and try to tap it off left and right, there should be a hole in the side for a spanner wrench, but I am not sure what thread it is. It should be right handed. Hope this helps.
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    Change jacobs 33 chuck powermatic 1150a
    In most column drillsis a narrow rectangular recess above the chuck when it is rotated slightly downwards
    therefore you should have one of these auxiliary tool
    At least the wedge
    Have not seen another system to remove a drill spindle
    Feb 27, 2016 | Powermatic 1150a Variable Speed Drill...
    What is the size of the taper on end of the spindle that takes the Jacobs chuck?
    if it is in a pedestal drill with a 1/2 inch chuck it can be no 1 morse taper if that is too small as some drills have capacity for larger chucks the there is a no 1 to no 2 adapter sleeve available
    Nov 09, 2015 | Drills
    How to remove drill chuck it is a jacobs 34-33c 33 chuck on a delta press
    Open the jaws of the chuck all the way. Stick a screw driver in it and turn it clockwise to loosen.
    Jan 24, 2014 | Drills
    How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
    Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
    Oct 17, 2013 | Delta Woodworking Drills
    The chuck is frozen on my 14,4 Black and Decker cordless drill. This is the second time that has happened with a Black and Decker drill so I assume it is a product defect. In use it was not that...
    Yes, they are an inferior product. However you can replace the B & D chuck with a Jacobs chuck that will hold up and last for a long time!
    Jacobs Chuck
    heatman101
    May 23, 2011 | Black & Decker Drills
    I want to put a taping head on my drill press. What is the spindle size of a craftsman 12" drill press?
    without the model number I am going to guess that as a general rule most smaller drill presses are a #2 morse taper socket and a #2 jacobs taper arbor (where the chuck presses on) you should have been supplied a knockout pin to remove the chuck assembly from the internal socket.
    Apr 15, 2011 | Craftsman 12" Drill Press (21914)
    Damaged chuck on a a.e.g. drill, chuck is one half inch, no screw inside chuck, how do i remove the chuck, the chuck brand is jacobs, thanks, jim
    Jacobs makes a couple different kinds. You say no screw inside so I would guess it is the tapered fit. It will require a couple of shims to be driven in between the chuck and head of the drill to press the chuck off. There are tools to do this but sometimes this can be done with shims. Shim each side the same and tap them in equally. If you are familiar with the pickle fork used on auto's to remove ball-joints, something like this may work as well. I hope this helps you.
    Jul 08, 2010 | Black & Decker Drills
    Removal of chuck
    Harold, Have you tried looking from the top? Maybe you can put a rod into the spindle from the top and give it a tap. Al Kupchella
    Apr 10, 2010 | Turner Walker-turner Rockwell 20 Inch...
    I have a Clarke BT 1001A and need a new chuck. The original never worked properly. Kept jamming. Where can I get a new chuck. 1/2 inch. The drill press is great.
    you should be able to look in the phone book under tools repair find one locally, on the chuck you have it should give you some number like 33BA or 2 Jacobs, you will need this information to make sure that you get the right one, I would try and find a Jacobs chuck for this, they make the better ones, I have used them as replacements for 26 years and the companies that I worked for prefer them. Let me know if you have trouble finding one and I would need that information also.
    Feb 07, 2010 | Clarke Power Products Clarke 16-Speed...
    Drills Logo
    203 people viewed this question
    Top Drills Experts
    Are you a Drill Expert? Answer questions, earn points and help others
