Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv wont stay powered on more than 3-4 min. It keeps powering itself off.
  • RCA Master
  • 5,138 Answers
Try cleaning contact switches on front panel
Menu/power/vol-/vol+/ch-/ch+
Posted on Jun 01, 2010
My tv keeps turning off when i turn it on it stays on for about 3 min and then it turns off by itself i replaced the lamp in the front and i keep having that problem any other ideas of what it could be it...
I sounds that the TV has main power regulator board problem. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Apr 14, 2013 | Panasonic PT-60LCX64 Television
My tv turns itself off after a few seconds or a few mins it just wont stay on
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
  1. Open the back cover.
  2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
  3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
  4. If the power supply output is normal..The problem could be on the main board...
  5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
  6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope thissolution will be helpful..
Thanks for using fixya...
Aug 12, 2011 | Televison & Video
It wont stay on it cuts itself off and on the power button has t
This seems to be a problem in the Power Supply I would think. Either that or a fault that is overloading the PSU.
This means a trip to the repair shop.
Make sure ya get a firm "Quote" for tha fix before proceeding.
Jan 20, 2010 | RCA HD56W58 56" HDTV
Keeps turning off
FIRST all projection TV's have bulbs.
Some have filters either on the bulb cage or on the outside of tv or both. When the bulb gets too hot it will protect itself by shutting off - clean and make sure they have good airflow.
Unless your D/s buddy has infared power not heard of - it's probably not him.
May 20, 2009 | Televison & Video
Television keeps going off by itself .comes on then goes off again after 5 mins and power button just goes red green red and wont come back on
overheating.open back hoover up dust carefully.
clean air vents.make sure air circulates around tv
Mar 15, 2009 | Televison & Video
RCA 32" SDTV
27V530t......my TV powers off and on all by itself and wont stay powered.Can you help ?
Jul 09, 2008 | RCA 32F531T 32" TV
Sony TV keeps shutting down ever 5 mins
Could be loose connections on the board where the solder is expanding as it heats up causing a loose connection or something in the power supply or horizontal is over heating and your tv is going into shutdown protection . Good luck
Mar 03, 2008 | Televison & Video
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
