Question about T-Mobile Wing™ Smartphone
T-mobile wing keyboards
My keyboard is not working just started doing that ... only half of the key are working anybody know any test i can rund or any soultions to fixing it?
  • Anonymous Oct 08, 2008
    yo i got the same problem bro...it really sucks
    Problem Solver:
  • 19 Answers
You may try a hard reset, or getting a replacement handset from t-mobile.
Posted on Jun 10, 2008
One Key, the Scandinavian o with a slash, is very slow after installing Windows 10
Are you talking about this ?. If so a trick to input it is to hold down the ALT key and press 149 on the numeric keypad. You can input all sorts of symbols, check out this list.
http://www.alt-codes.net/
May 01, 2016 | Microsoft New 200 Keyboard Wired Black Usb...
How do I speed up my keyboard keys?
Sounds like the keyboard may be faulty. Have you tried an external USB keyboard to test the system drivers?
Jan 29, 2016 | Toshiba Computers & Internet
Shift key not functioning.
You have selected the wrong keyboard language.
Go to Control Panel select Region and Language. Change the keyboard to your layout. (Probably US).
Nov 16, 2013 | Acer Aspire One PC Notebook
Cannot start windows in HP netbook... enter key not working to select any mode...
If your HP netbook not working properly so now you can easily fix this type of error simply Dial HP customer support Toll-free number > 1-877-227-5694 and Fix your netbook error fast. Our Website is >> HP Customer Support Phone Number 1 877 227 5694 for Tech Help
Oct 05, 2017 | HP Mini 1000 Netbook
Even though it seems to be working just fine, I think my keyboard is sending a signal to the computer without me knowing (or actually typing anything)--I've been having some computer troubles lately, and...
The easiest way to find out if it is your keyboard is to temporarily trade keyboards with someone. You will know quickly. It is not necessary to use a Dell keyboard.
Jul 28, 2009 | Dell 0Y3740 Keyboard
TMobile wing dials the last number multiple times automatically.
I think maybe the dial button is messed up (Under the key).
You know how sometimes when something stuck in certain key of ur pc keyboard, it will keep typing that letter?!
You might just need clean under the dial button.
Jan 25, 2009 | T-Mobile Wing™ Smartphone
Can I unlock my T.mobile with my keyboard?
1) Open the keyboard.
2) Press the dash looking key above the 'R' and 'T' keys to enter the Unlock mode. The screen will change asking to tap "Unlock" or press "*".
3) Hold the ALT key and press the 'V' key (really '*').
This will unlock the unlock the unit.
Jan 12, 2009 | T-Mobile Wing™ Smartphone
@ key not working
Keyboards can become dirty after periods of extended use, especially if users commonly eat or smoke near the computer. If a keyboard becomes dirty enough, its performance can be affected. Common problems include dead or stuck keys and repeated characters during typing.
Shut down the computer and detach the keyboard connector before any cleaning procedure. Do not remove or connect a keyboard while the computer is running. Doing so may damage the machine, especially a non-USB based keyboard
For a quick cleaning, turn the keyboard upside down and use a can of compressed air to blow out any foreign matter. Be sure to do this in a location where falling debris can be cleaned up easily. Turn the keyboard upside down and tap on it a few times. You should see a bit of dirt fall out. Change the angle and tap harder to make most of it get out
Clean the sides of the keys with a cotton swab dipped in isopropyl alcohol.
For a more thorough cleaning, remove all of the keys. Do this by gently prying up each key with a small screwdriver or a similar lever. When the keys have been removed, blow out any debris with compressed air. With a moist (but not wet) cloth, lightly swab all surfaces. Do not allow any type of fluid to enter the keyboard.
Clean the individual keys and place them back in the keyboard.
and an alternate method : Alternate Method
  1. Switch off the machine and disconnect the keyboard.
  2. Turn the keyboard upside down and remove all the screws.
  3. Lift the top half of the keyboard (The one with the keys on it) off and put the bottom half to one side.
    • There may be some clips on the keyboard, also, check for screws hidden under labels.
  4. Turn the top half around so that you can see the backs of the keys, squeeze the tabs on each key to remove it, the space-bar will have a metal rod, this may be a pain to refit, but is not impossible.
  5. Fill a bowl with hot soapy water (Fairy Liquid works well)
  6. Dump the keys into the bowl and scrub with a brush.
  7. Remove the keys and leave to dry or dry with a hair dryer.
  8. Place the empty top half of the keyboard into the bowl and scrub until clean.
  9. Once everything is dry, reassemble the keyboard.
  10. Press both halves of the keyboard firmly together, if you miss the clips in the middle your keys wont reach the circuits and wont spring up.
  11. Plug in your keyboard, switch on your PC, enjoy.
Oct 08, 2008 | Computers & Internet
Please help
I actually just took the whole entire thing apart. I am a female and pretty mechanical. I found it really easy. I am only have 2 problems with the phone now. Half of my keyboard isn't working and the charger connection is loose. Thanks.
Mar 05, 2008 | T-Mobile Wing™ Smartphone
T-Mobile Wing™ Smartphone Logo
63 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
