Question about Zanussi Washing Machines
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Posted on Feb 07, 2011
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
Zanussi electolux aquacycle 1200 w/mc wont spin
Try new bushes and make sure where bushes run is clean and free from carbon H
Jan 09, 2010 | Electrolux Washing Machines
Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Oct 06, 2009 | Zanussi ZWF1430W Front Load Washer
I have zanussi aquacycle fls1183w and it started stopping halfway through cycle light stays on
Has still a conventional timer clock?
Then most probably a piece broke of.
In the old days on those I would open it up see which tooth broke of by revolving the timer and replace carefully with a little screw after carefully drilling into the plastic, obtaining the same heighth. Happily lived 10 years more.
Apr 16, 2009 | Washing Machines
Zanussi aquacycle 1400 fle 1416w started to make an electric arking noise when spinning now. Now it has stopped spinning. Will the motor be dead or will it just be the carbon bushes that need replacing....
Hiya Cheap6... more than likely the brushes.. which are easily checked to see if they are worn down.. otherwise its a new or RE-con motor.
Regards Faggly
Mar 21, 2008 | Washing Machines
No spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Obstacle wire stuck in drum (model FLS1183W)
you will have to split the case u will find 6 8mm bolt under the lid remove the 2 rear looking from the front then down the sides u will see 2 round plastic covers remove them by putting a small screw driver in the centre of the lug there r another 8mm bolt in each side use a small screw driver to remove the mains and valve block now the cabinet will split u will need a 10mm socket to remove the heater and a claw hammer to get the heater out of its housing use the claw by caerfully placeing it under the terminal 1side @ a time and the heater will come out u will be able to get the bra wire out from there u may need a set of long nose plyers good luck and make sure u have unplugged the machine b4 u start any dissmanteling
Nov 28, 2006 | Zanussi FS1155W Front Load Washer
Washing Machines Logo
424 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
