Question about Stone Saws
How to break stone edge of walk way with heat? new home stone people told me that you can use a torch to heat up stone to get a natural look to it ?
  • 623 Answers
Yes you can use heat. It actually fractures off the top layer of rock. It's called a flame finish if you want to research ot further.
Posted on Jun 02, 2010
How do I cut up a large mirror?
Essentially the same as cutting glass. Get a glass cutter with a new sharp wheel. Practice on a piece of scrap glass the touch. Firm but not too heavy then make a smooth stroke along a straight edge to guide your cut.
Put a t' thick board under the line to be broken with the board to the left of your intended cut then make a push down on the glass to the right of the break line. If you have made a good continuous scribe line in the glass completely along your cut line it will snap cleanly into your desired two pieces. Repeat until you have the sizes you want. It will only break in straight lines in this method.
Us a torch to burn the edge corners to keep them from cutting you. Just heat it long enough to round the sharp edge.
Jul 02, 2014 | Home
Lava stone grill
Cheers--Miele.com.au looks like next door :-)
Aug 02, 2017 | Miele Dishwashers
Which methods are there for cutting bottles?
According to Wikipedia these are the bottle cutting methods:
Rope Method:
The rope method is a common practice for those novice at cutting glass bottles. The idea is to take a rope or piece of string and tie it tightly to the bottle directly into score line. The string is to be then painted with a flammable oil then set on fire. The heat that comes from the burning string will cause the bottle to soften in the score. While the score is still warm, the bottle is then placed under a flow of cold water which will tighten the heated molecules at such a quick rate that the stress of the bottle is released through your score causing a break in the glass. Problems with this method include the stress in the bottle being so great that the bottle fails to break immediately on the score line and will leave large jagged pieces that take a long time to grind down.
Torch Method:
The torch method is very similar to the rope method but requires a much more practiced hand in cutting bottles. The idea here is to use a torch to heat the bottle over the score line until the bottle reaches appropriate temperature to then place under the cold running water. Problems that occur with this method include still large jagged edges much like the rope method, however, much more accurate to the score. An advantage to this method is the lack of material and cost with a quicker and cleaner result.
Water Method:
Although all methods include a cold stream, this is the only method in which to make a cut using entirely water. Problems that occur in the rope method and the torch method is that the glass becomes too hot too quickly making inaccurate breaks with large stress lines and fractures in the glass. With the water method, you can obtain an almost perfect cut and at a faster and cheaper rate than almost all other methods. In this method, boiling water is poured slowly on the score line raising the temperature in the glass at a much slower rate than a fire method and will maintain a much lower temperature. Once the bottle becomes warm, it is then placed under the cold running water for the break. Problems still occur during this method with sometimes jagged edges and stress lines and fractures, however; most methods are a 50%-60% success rate, where as the water method is about a 95% success rate.
Oct 07, 2013 | Cutter Tools
What are the advantages of cork flooring?
Cork flooring has many advantages. Cork flooring is comfortable and easy to walk on, the cellular structure of cork makes the floor very durable which can absorb sounds and blows making the cork floor a great pick for apartments and condominiums.
Feb 06, 2013 | Building Materials
What do they mean by engineered stone for my countertop?
it is quartz powder that is fused together at a very high heat. You can make it in patterns to look very much like granite, or other colors or patterns
Jan 16, 2013 | Building Materials
What should I use for sharpening diamond stone or natural stone?
These days we can see that the artificial stones match in quality to natural stones and sometimes even better in sharpening performance due to consistency of particle size and control over the properties of the stones. When artificial stones gradually entered the market and were of good quality. Mines of Natural stone where closed and that caused the prices for natural stone to go higher. These days, getting quality natural stone is an expensive issue.
Jan 14, 2013 | Hunting
Not enough heat using natural gas and oxygen
Try mapp gas.........I have a small torch with mapp gas and works well for small stuff. Hardware store/Home Depo.............
Dec 20, 2009 | Smith LITTLE TORCH 23-1001D JEWELER'S...
What is the best product to re-paint external stone windowsill
As any good stone mason knows, painting stone is NOT RECOMMENDED!  Stone has a natural beauty and durability that cant really be improved upon.  Its my opinion that paint on stone or brick usually looks horrible.  Especially when the paint gets old and begins to deteriorate.  Stone is a natural material used in building for thousands of years.  It is strong, durable, insulating from heat and cold and allows the structure to "breathe" while keeping out moisture and preventing condensation.  Painting stone stops its ability to "breathe" and effectively closes its pores, which can cause condensation inside walls, break down the stone's surface molecules and premature erosion.       I would recommend power washing or sand blasting the surface to remove the old paint.  Then carefully apply a waterproofer / sealant made for exterior use and stone in particular.  This will protect your stone window sills and lentils from harsh elements like acid rain, bird poop and ice while  allowing the structure to breathe and look beautiful naturally for decades to come.    I would not recommend sanding as this might change the surface of your stone and leave unsightly scratches and uneven surfaces.    You can look online for solutions by googling "stone waterproofing" and "stone cleaning" before deciding what is best for you.  I highly recommend NOT painting exterior stone.  Here are a few helpful results I have found.
http://www.hytechsales.com/prod52.html
http://www.tonygraham.co.uk/paint_remove_house.htm
http://books.google.com/books?id=gs6Fu-OUhRIC&pg=PA81&lpg=PA81&dq=paint+removal+for+stone&source=bl&ots=VtQHht57iq&sig=He1aHsOMYpW1aU4mxuStkJgrH7E&hl=en&sa=X&oi=book_result&resnum=4&ct=result#PPA79,M1
Wishing you the best results and an easy job!   Michael Mittelsdorf
Dec 28, 2008 | Tools & Hardware - Others
Installing a drop-in sink
The stone installer told you to use silicone,
what makes you think that you know more than he does about his product.
IF you go use lockdown screws, you will put tension on a thin granite slab at 4 or 6 points around the perimeter of a hole.
stone breaks under very small tensions
do as instructed and silicone the sink in place,
or void any warranty and buy the counter top again when you break it
formica is plastic on a chipboard substrate -not stone
not perhaps the answer you want to hear,
Sep 09, 2008 | Air Tools & Compressors
Tile Saw Troubleshooting
options, change the blade, buy a more expensive blade, make sure the blade turns true when running, if not the armeture might bent inside the saw.
Aug 27, 2008 | Mk Diamond 5.3 amp Tile Saw
Saws Logo
83 people viewed this question
Top Stone Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Stone Saw Expert? Answer questions, earn points and help others
