Question about Sony STR-DG820 Receiver
Hd picture My playstation 3 was working perfectly with the receiver for 2 or 3 months. Then one night it stopedd working. It is plugged into the HDMI port. Before the settings are changed to HD on my PS3, the picture on the TV looks kind of rainbowish and bad quality and then when I switch the settings to 1080, the TV does not show any picture at all. The TV says unsupported mode then "No Signal" I tried an xbox in the same HDMI port and it worked fine then I tried a blu-ray player in the same port and again the video did not work. with both the Blu-ray and PS3 I can here sound but no video
  • 45 Answers
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Posted on Jun 02, 2010
HDMI 1 and HDMI 2 no longer work on my TV. What can I do to repair this?
Sounds like you have a bad input board and it is only time before you lose three. If it is under warranty get it in otherwise start tracking down the part. Most of these are a plug and play device once the tv is apart.
Oct 07, 2012 | Panasonic Tc-p50g20 Viera G20 Series 50"...
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Just set up RX-A700 two things seem wrong. 1. HDMI 1 won't show video if HDMI is plugged in, once plug on HDMI is removed from receiver HDMI 1 works perfectly. 2. HDMI output needs to be held tight or else...
sounds to me like a bad HDMI cable. Just replace it.
If HDMI still wont show, move to another HDMI port. But based on having to hold HDMI cable with hand to steady the connection, it is either a bad HDMI cable, or a bad HDMI port on the receiver. Good luck
Jan 23, 2011 | Yamaha RXA700 Receiver
I have an optoma HD20 and it connects using a 1.5m HDMI but as soon as i try a 10m HDMI connection (even with a booster it does not connect) any suggestions welcomed?
Hi kgomer782 I have similar issue. My optoma hd20 signal connection with a 3/6ft hdmi cable is perfect. However, no signal is detected when connected to a 35ft hdmi 1.4 cable. The 35ft cable is indeed working becuase I tested it succesfully when connected to a 1080p HDTV. Did you received any solution to your problem? I wonder if it has anything to do with the HD20 design of the "debossed" hdmi ports that prevents the cable plug from getting completely "seated" in the port? My 35ft cable has a flat square male ending however, the 3/6ft cables have slim male ending that seems to accomodate perfectly in the Optoma's hdmi port design...kaufmanekpr
Aug 07, 2010 | Optoma HD20 DLP Projector
My hdmi plug in the playstation does not work i have set the playstation to hd but it dont work ive tried to cables and to diffrent tvs
Solution
Remove SCART leads, plug in HDMI from PS3 to TV HDMI 1 port.
Now......
Turn OFF TV, turn OFF PS3
Wait 15 seconds
Turn on TV
Press and Hold PS3 On switch until it has completed one recycle.
Now wait 2 secs and you should get the handshake and connection.
Jul 15, 2010 | Sony Playstation 3 (PS3) Console
HDMI ports will not work
Unplug the tv,satalite box and playstation 3,replug all the devices about an hour later.Go in ur tv menu,goto PICTURE,go down to reset the Tv Tuner board,will reset the tv Tuner board will reset it back to factory setting.Than still have the same problems.The tv Tuner board it dead,require the Tv tuner replacement.
Jun 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Jan 20, 2010 | Onkyo TX-SR606 Receiver
Help!
It is possible that the HDMI ports are blown. The work through their own circuit area in the TV set. This is a particularly complex area.
You will have to send the set to the authorized service rep for an estimate. See if your home insurance plan will cover for this type of thing. Some types of home policies will cover for this type of thing. The cost of servicing your set may be expensive. Damage from a lightning strike will not normaly be covered by warranty.
Jerry G.
Jun 12, 2008 | Mitsubishi WD-Y657 65" HDTV
PS3 no longer communicating with TV
All: Try this -
P
erform the following steps to reset the Video Output Settings.
  1. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  3. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor). [If resetting does not auto-detect your HDTV, see next step below.]
NOTE: As of system software update version 1.60, the PLAYSTATION 3can automatically detect an HDMI connection to a TV. If the PLAYSTATION 3 is turned on with an HDMI cable connected, the screen for switching video output settings will be displayed automatically. (Does not function unless the TV that is connected by the HDMI cable is turned on.)
As of version 1.80 of the system update for the PLAYSTATION 3, the PLAYSTATION 3 can upscale the video content of PlayStation® format software, PlayStation®2 format software, and DVDs to HD resolution.
If Resetting the Video Output Setting Did NOT Detect Your HDTV Automatically (Certain TV's Only)
With certain televisions, the PLAYSTATION 3 may not automatically detect the HDMI source (TV) which it is plugged into, even after resetting the Video Output Setting (as described above).
If resetting the Video Output Setting did not work, you may need to follow these steps to manually locate the HDMI source:
1. Connect both the AV Cable and the HDMI cable from the PLAYSTATION 3 to the corresponding (AV and HDMI) ports on your TV. 2. Proceed with resetting the Video Output Setting on the PLAYSTATION 3 again. (Follow these steps, then continue to step 3 below.)
3. Turn the TV channel to the corresponding "Input" or "Video" channel for the AV Cable connection.
4. Manually change the Video Output Settings to HDMI. (Follow these steps, then continue to step 5 below.)
5. Now switch the "Input" or "Video" channel on the TV for the HDMI port the PLAYSTATION 3 is currently plugged into.
6. Accept the display settings for HDMI before the timer runs out (30 seconds). Highlight "Yes" and press the X button.
7. You can now disconnect AV Cable from the PLAYSTATION 3 and the TV, as it is no longer needed.
Dec 16, 2007 | Sony Playstation 3 (PS3) Console
Open Questions:
See all Sony STR-DG820 Receiver Questions
Sony STR-DG820 Receiver Logo
320 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
