Question about Kenmore 63942 Dryer
Kenmore Gas Dryer 70956990 -- The dryer tries to
Kenmore Gas Dryer 70956990 -- The dryer tries to kick on but just hums then kicks off thern about a minute later its tries to kick on again - door switch Ok - The motor seems to be free and the drum moves OK (all with the belts attached and connected - moved with the blower wheel
  • ceasariam Jun 02, 2010
    Thank you! I appreciate the help. My best bet is to have it done then.
    President:
  • 1,554 Answers
It is definitely not a belt issue; otherwise no humming noise is heard from the motor since a switch which is wired in series with the motor circuit is being activated by the belt by means of a lever. The motor never runs without the belt on. The issue is rather with the motor being the rotor locked when the motor is turned on. The may seem free when not turned on. It can be verified by opening the dryer door then activating the door switch manually. Push and hold the door switch and start the dryer then turn the drum manually while still holding on the door switch. It is indeed a locked rotor issue if the drum does not turn freely and the motor (part number 279787) needs to be replaced. Otherwise, check the belt for slippage especially when the blower wheel turns but not the drum.
The cyclic attempt of the motor to kick in is normal indicating that the relay on the electronic dryness control is working.
Posted on Jun 01, 2010
    I tried you suggestion. The drum does move but not freely. it is a litle tight and the mototr does not kick in. I did hear a click then and the whole motor seemed to kick off. Is it hard to replace the mottor? Do i go in from the back or the front?
  • Jahn27
    Jahn27 Jun 02, 2010
    Replacing the motor is the most difficult repair task with a dryer regardless of make and model as it requires a complete tear down of a dryer. Access to the motor requires the removal, in particular order, of top cover, front panel, toe panel, drum, and the blower wheel.
Thermal fuse location on a 110.9597590110 gas dryer
The model number of your machine doesn't seem to exist but the thermal fuse, whether dryer is electric or gas, is always located on the blower housing together with the thermistor or cycling thermostat depending on the model of the dryer. The blower housing is located at the rear of the dryer if the lint filter of you dryer is located on top of the cabinet and can be accessed by removing the rear panel.
The blower housing is located on the front right bottom of the dryer if the lint filter is located on the door. It can be accessed by removing the kick panel.
Kick Panel Removal
Once the kick panel is removed, remove the lint chute to expose the blower housing and the thermal fuse.
Sep 30, 2010 | Kenmore Dryers
Kenmore dryer model # 110. 79902890 press the
you have a problem with a component called a capacitor.the capacitor stores an electric charge.this charge gives the motor the "kick" needs to start.if you have a faulty one the motor will hum because it cant turn.it should only be replaced by a competent appliance technician.
Oct 07, 2009 | Dryers
Where are the gas solenoids on a Kenmore gas dryer and how do I get to them?
If your dryer has a bottom kick plate pull it off and the gas solenoids are on the left side can’t miss. If you don’t have the kick plate the front of the dryer must come off. The whole front will come off very easy just lift the top up from the front and the remove two screws on each side hold the front on and lift the front up and off be careful of wire’s to the door.
bobby18rg@hotmail.com
Jul 14, 2009 | Kenmore 74832 Gas Dryer
Dryer won't heat
sounds like your heating element
Jun 09, 2009 | Maytag MDG4000 Dryer
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Ge Gas Dryer the drum does not turn but motor just hums then kicks out
sounds like motor bearings or drum bearings are froze up and is not turning the belt.
Apr 24, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Kenmore dryer stops
does the motor hum when you push start? if so then your drive motor is bad.
Nov 11, 2008 | Kenmore Dryers
Dryer problem
Hi. thanks for the question . It looks like you have a faulty motor . I would replace the motor , thanks the appliance doc
Sep 20, 2008 | Kenmore 72802 Gas Dryer
Kenmore 63942 Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
